mitigating wind noise ?
would placing a thin rubber hose inside the doors/windows stripping ( seals, or whatever the hollow lining is called ) keep everything tighter and possibly reduce wind noise ?
Has anyone "tested" this in the past ?
you would be amazed at how little a misalignment of a door it takes to make wind noise - i would consider looking into that before adding any material - a few thousanths of an inch is often all it takes to quiet things down
speaking of which, I've been getting a bit more wind noise from my passanger door than usual. Bob, next time I'm at your house, can you help me realign my door a bit. Two people is so much easier.
Rustech
sure - no worries - see if you can have somebody in the passenger seat push on the window a bit as you drive to see where exactly the air leak is - that will help me figure out which angle to move the door, though i can always just use the "goo" test
[quote name='flash' date='May 6 2005, 11:01 AM']you would be amazed at how little a misalignment of a door it takes to make wind noise - i would consider looking into that before adding any material - a few thousanths of an inch is often all it takes to quiet things down
[right][post="4391"]<{POST_SNAPBACK}>[/post][/right][/quote]
how can a door get misaligned without it being removed first ? and more importantly how could I tell if it's shifted just by a few thousands of an inch ?!
It looks even with the side panels on both the bottom 2 / 3, but to the eye the
top 1 / 3 does seem to protrude out a bit. However, since that's the case for both doors I'm not so sure that's not the normal design.
So what to do ? push the top of the door and pull the bottom part simultaneously, drive it, and if it's louder push / pull the other way and test that result ?
they sag over time - really no way to tell visually if it is only a few thousandths - you can do a "goo" test (call me and i'll explain this one) - you can also do as i indicated to eric with a passenger
the process to correct is easy when you know how to do it - it's complicated and potentially damaging if you don't - when is the next time you are down here?
paso robles is only a month away ( that's if we stick with the 11th ) so that should work out.. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
[quote name='flash' date='May 6 2005, 04:00 PM']they sag over time -
[right][post="4413"]<{POST_SNAPBACK}>[/post][/right][/quote]
doesn't everything ? <img src="/forum/images/smilies/968/dry.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />
what, your boobs at your waist? <img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" />
Rustech
he, he - I guess that's true for both genders. besides, as men get older the waist seems to rise proportionately with age ( that's why all granpas wear their pants riding so high, the belt is just about at "boob" level ), so your comment is not that far off from reality...just that in my case it won't happen for another 40 years or so.. <img src="/forum/images/smilies/968/cool.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Had nothing better to do this morning, so I went to Orchard Supply and bought
30 ft of rubber stripping ( the kind that goes on screen doors holding the mesh / net in place ) for a whoping $4, and for another $3, got 30ft of plastic tube ( a bit thicker than the stripping, not sure what diameter, but tested a sample first to make sure it fits) and inserted them all around the doors seals. Did the narrower one one first, drove the car, replaced with the tubing, drove the car again, and : no difference noticed by having either filler in place. <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" />
Just wanted to test the tight seal theory ( hmm, tight seal..sounds like a walrus' dream date <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" /> .. )
So, waiting for plan B : Paso Robles "inspection" by the 968-savy crowd.
actually, can probably do it right then and there in about 15 minutes
DS968,
Quote"
Just wanted to test the tight seal theory ( hmm, tight seal..sounds like a walrus' dream date <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" /> .. )"
ROFLAMAO
Silver BLT
<img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
DS968,
You crack me UP!! I just looked at the thread title differently and have an answer for.
"mitigating wind noise?"
Try eating more vegetables <img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" />
Silver BLT
I'm betting you'd have a field day with some of the titles of threads posted on 968.net in the last year - tough to remember some of the better ones but on a slow day, after a couple of glasses of wine.. scroll trough the forum... good for a laugh or two.
HA! Reminds me of a Kip Adotta Novelty song:
It was April the 41st, it being a quadruple leap year and I was driving in downtown Atlantis. My Barracuda was in the shop, so I was in a rented Stingray, and it was over-heating. So, I pulled into a Shell station. They said I'd blown a seal. I said, "Fix the damned thing, and leave my private life out of it, okay pal?"
Kip recycled an old joke about an eskimo being told that by the gas station attendant, to which he replied : Nah, that's just frost on my mustache..
barrramp pum. got a million of them. thank you, thank you. I'll be here all week.
remember to tip the waitresses. and try the veal .
or, did you hear the one about Heidi Klum pulling into an auto repair shop...
ok, I better quit before you moderators will remove this post.
time for " Family Guy " anyway..
or is it Claudia Schiffer that's his g.f. / wife ? can't keep track of celebrities any more..
Last Post by Gotter
03-28-2008, 07:04 PM
Last Post by Darth Vadar
06-02-2007, 07:12 PM
Last Post by csc71
05-19-2006, 06:15 PM
03-26-2006, 01:12 PM
