Flash,
I am much the same way about making a conversion OE quality and reliability, all of my engine control wiring passes through the original Porsche harness boot on the firewall. Let me tell you unpinning the harness so I could use the factory boot was a bitch but in the end it looks OE. I use the factory DME relay to control the fuel pump and ECU signal so any trouble shooting would be in the same location as the OE wiring. Concerning transmission ratios, I have done a lot of research and it was interesting to discover how close the 951 gear ratios were to Tremec TKO 5 speed transmission that are typically used V8 engines.
Tremec-3.27-1.97-1.34-1.00-.68 Typically run with 3.55 final drive or higher.
951 3.50-2.05-1.40-1.03-.85 S2-5th .78 NA-5th .73
As you can see the ratios are very close, and with a 3.375 final drive the gearing is pretty well matched for a V8.
Changing the first and second gear ratios in the 951 or 968 gearboxes would be difficult as 1st and 2nd are made on the main shaft and are not removable.
I tried for 2 years to get a custom R&P for my 6 speed but it was cost prohibitive; I even put a .60 6th gear in the 6 speed but the rest of the ratios were just too low to make good use of the V8 torque. Eventually I went the 5 speed route and it has worked great for me and many others. The 5 speeds are not that expensive so I have a spare Turbo S box that I paid $1300 for so if I do break one it is not a high dollar fix.
I hope you will drive Tony's car; it is more of a track/race car but I think you will see the the transmission is up to the task and the power is intoxicating.
<!--quoteo(post=78617:date=Aug 24 2009, 10:35 PM:name=flash)-->QUOTE (flash @ Aug 24 2009, 10:35 PM)
<{POST_SNAPBACK}><!--quotec-->i don't know that we actually disagree all that much - we both think it's great power and can work in a 968 - i think it may come down to a standard of acceptability - i am extremely strict and demanding - i won't drive a car with tires half worn, or makes rattles and such, is dented, yada yada - i even wax my engine bays on all of my cars (just did the denali day before yesterday)
i am the same way about conversions, and i've done plenty of them - sure we did some that were really fast hack jobs that we ran for a weekend just to beat a particular car, and then scrapped - but the others were full on street cars that had to be absolutely perfect - for the 968 i would accept nothing less than OEM quality standard - i would expect all wiring and such to be properly dressed, no rattles or squeaks, no strain on components, etc
i am sure it can be done - no question - to do it right, all i am saying is that it won't be cheap or quick - in the end though, you would have one heck of a car
if i get bored enough with the power i have, i may yet do this - however, i will definitely be raising the ratios of 1st and 2nd, as well as raising the ring and pinion ratio - i've sheared off too may 1st gears in my day, and snapped way too may ring gears to do otherwise - maybe the box can handle it if you nurse it, but that is not why i would have this car - i do like the idea of the taller final gear
as for the engine in my yukon, it is perfect - had it checked out fully twice, since in have blown 2 transmissions, 2 front diffs, and a transfer case - it is indeed a very strong powerplant - however, it definitely warms up at 4k, though not horribly - i don't keep it there for too long though, and you can hear how out of balance the engine is - i've heard the same thing in almost every stock chevy small block, which is why if i did this, i would tear down the engine and balance everything - i still think it is a great power plant, but has its limits that need to be considered, which is why they made so many different versions of the engine, transmissions and rear ends in the cars they built
i think i need to ring up tony and take his out for a spin<!--QuoteEnd--><!--QuoteEEnd-->
