Threads: 51
Re: tweeter replacement
[indent=1]No question about replacing the old tweeters. Just a question about abandoning the old tweeter LOCATION as my new JBA C5-625x is coaxial. [/indent]
Re: tweeters in the back or not?
[indent=1]There has been some discussion on this issue here in the past, both pro and con. I'm running with the recommendation that full-frequency from the rear speakers is a good thing, adding dimension. dry, I can certainly see your point about too much "surround sound" - certainly something to fine-tune later as required.[/indent]
Re: pics
[indent=1]Coming soon.[/indent]
(This post was last modified: 08-13-2014, 07:12 PM by
apex.)
Threads: 51
Two questions related to my install.
First - I buggered up my rear panel anchor anchor. What's the recommended fix? Just glue the panel anchor back in?
Second - Identified a mysterious leak in the back which drains into the wheel well - a broken grommet serving the left rear brake light. Anyone got a part number? I can't find it in the PET.
Cheers,
J
on edit: forgot to post the images.
(This post was last modified: 08-15-2014, 07:02 PM by
apex.)
Threads: 51
flash the "rear panel anchor" is simply the plastic snap-in piece holding the interior trim panel in place over the rear speaker. It pulled from the cardboard. I've epoxied it back in place - hopefully that will do the trick - there are three per panel, I believe, and this one on both sides for some reason is VERY hard to remove from the car once pressed back.
I've fixed the sunroof leak already! This leak - ha - since I watched the water come in - is definitely through the left brake light grommet - broken as shown. This is the same rubber piece used at the firewall. There's a part number stamped on it - I'll ID it later today.
Threads: 51
re: tool - Dude! I have about six of those tools. The snapper in question is hard to see on removal. Chalk it up to a mis-fire.
re: brake light leak - Obviously surface-tension driven water entry - might be following the electric wire. Porsche took pains to seal up all the connections with rubber - I think they knew what they were doing. I've watched the water come in. About that grommet - the firewall version of it has a 928 part number on it. The rear brake light version does not. Need to check and see if they are really the same or not.
Progress report - with some questions - see pics
- Becker head required that I Dremel off the interior spring clamps.
- Installed sound deadening everywhere - well doors, rear speaker area, and to rear below the hatch. The doors on my car already have factory deadening on the upper half of the door - so didn't go back over that with new stuff there.
- power wire installed - what do you guys do about the fuse holder? Screw it in somewhere or just let it ride in the battery compartment. I'm disinclined to drill more holes in my sheet metal to hold the fuse.
- speaker wires run - I chose to run the speaker wire through the hollow rocker panels both sides. My RCAs will run along the left side of the interior, and power wire on the right interior.
- after running new wire did the rear speaker mod both sides - those recesses are screaming for my new JL's now.
- In running driver's door wiring I think I found the reason why my right-hand mirror stopped adjusting - the white/brown wire is broken - almost looks CUT. Need to look more closely at what caused that.
To do:
- Suss out the amp mounting - there's a small tab with hole above the right rear cubby - unused - matching one on the left used to hold the sunroof mechanism cover - so this must be for RHD cars. This makes a great spot to anchor a small angle across to the wheel well - I can attach to the wheel well with a screw - this angle will hold by MDO amp/equalizer board in place. I really don't want to penetrate the cubby wall with screws - the gas tank is right there... so far so good you can see the cardboard template.
- Grounding. The afore-mentioned tab looks good. But the factory ground point on the other side of the spare wheel well looks better - trouble is my ground cord is not long enough. The JL literature that came with my amp says to use a grounding wire no longer than 36". The one I have is 18".
Has anyone else installed an amp in one of the small cubbies? I'm keeping the spare tire for now. The JL XD440/4 is a sweet, small amp and fits easily in the small cubby but mounting strategies are not obvious.
Threads: 51
<img src="/forum/images/smilies/968/wink.png" class="smilie" alt="" /> Sorry - this thread is all over the board - water leaks, electronics, audio fidelity. But ain't that how it usually goes - no matter how focused the 968 project there is ALWAYS scope creep. So forgive me for inflicting my scope creep on the forum.
re: air sealing
In thinking about the front 525's - following on the air-sealing project for the rears - what's the best way to air-seal the front stock speaker locations? Or *is* there a way? Do
waterproof foam cups work?
Threads: 51
Thanks, mates. What I think I'm hearing both of you say is to leave well enough alone and go with the stock install up front - don't screw around with it, other than change out the speaker. Right?
Threads: 51
Following on the air sealing topic: The 3 inch speaker goes as part of this install. From an acoustics perspective should I bother to cut a 3 x 3" piece of plastic and seal the opening that is there for it in the door pocket?
Not sealed is not sealed, right? Or is there a difference between "big gaping hole " vs "air leaks"? :-)
And as for the rear speakers (now in a sealed enclosure) - utterly seal every little screw hole and gap? Airtight, right?
Threads: 51
dry,
Thanks for your help and info - I really appreciate it.
re: front door
OK - seal up the speaker-to-plastic-armature as well as possible to isolate front from back. Ha - I *did* indeed cut a piece of plastic to fill the 3" mid-range hole. I'll go back and silicone it tight.
As for the weather seal - I wonder if there isn't a way to layer two sheets of plastic in a roofer's flashing/counterflashing technique such that any interior drips are shed back into the door, but allowing air to move easily through? I have to completely re-build my door seals anyway. You will have to tell me how this idea comports with basic speaker theory.
re: rears
Yep - I'm gonna seal those suckers up tight.
re: lack of mid-bass in front
The C5-525s and crossovers are installed in their armatures. The crossover has two adjustments - something called "midrange presence" (low, high, reference) and "tweeter level" (+2db, reference, -1.5db, -3db). I won't have an EQ initially. Knowing what you know about the car, what would you recommend as initial settings? Or should I just leave it up to my ear?
re: excellent recordings
Sure - pass along some titles! Thanks.
