Intro and a few questions
First of all I would like to say Hello, join recently to do some research on the 968. I have been knocking around the idea of picking up a 6 speed cab in the near future (the other car in the running is a 951), been awhile since I had a P-car, started with a '76 914 2.0, then '72 914, then '86 944 N/A, and a '92 944S2 Cab, and finally a '70 914 last. I have been searching to see if the things to be aware of when buying a 968 are the same as a 944, mainly timing belt and wasser pump. So far I have enjoyed reading about all the cars you guys have and I am looking forward to adding to the mayhem.
John Hudson
Memphis (not really but it is the closest big city)
Good luck in your search and welcome to the forum.
As for things to look for, keep reading the forum. You'll identify them quickly. The big thing with a six-speed car is the pinion bearing but by now most of the problems have occurred and been repaired. Most. Not all. Watch out on lower-mileage cars.
Duckman:  Koni sport yellow adjustable shocks, M030 sway bars; KLA strut tower brace; Mille Miglia Cup III 18" wheels, 8.5" & 10.0" w/ 235/40 & 275/35 Goodyear F1s; airbox mod; AutoThority chip; custom exhaust with MagnaFlow muffler and 3" straight-through pipe; Euro lenses; Tenzo R sport seats.
Welcome John,
As for your questions "Yes" many of the same things can go wrong and need to be checked for as well as the pinion bearings (noise) and vario cam chain/pads (They wear after a time and need replacing) other wise they are almost bullet proof and less trouble than the 951.
Rick
yes - welcome - there are a few idiosyncrasies with this car, but that can be said of most any car
the pinion bearing issue is not nearly as bad as it has been made out - the occurrence, while certainly high for any such issue, only hit about 10% of the cars, and can happen at any time, regardless of mileage or age - it has nothing whatsoever to do with mileage, age of the car, or any other factor - it was merely a tolerance accumulation problem at the time of install - the variance is due to how much of the tolerance error was present on that particular car - the bearing was mechanically installed, and the amount of preload variance is the issue - those with the most preload failed first - those with a little less, failed later - those installed correctly, don't fail at all
but no matter what, the resolution is not that expensive if you catch it when it first starts making noise - it is generally about $1700
good luck
Last Post by PorscheDude
07-11-2008, 03:36 PM
Last Post by RS Barn
07-09-2008, 10:57 AM
Last Post by RPM
01-24-2006, 05:49 PM
