Threads: 167
I had an annoying squeak in the passenger seat...a bit of duct tape on her mouth and Viola'...fixed..
Ba-dum-bum...
Threads: 19
Jay, thanks for the chuckle.
'92 Midnight Blue 968 Coupe
Threads: 17
In my case it was the black piece under the spoiler it has 4 allenbolts an shims under there . . The ends were making the noise .
volvo V70D5 Black
Porsche 968 amethyst
Threads: 15
I had a rattle too in the same area, I tightened the spoiler and solved the issue but you said you already tightened the spoiler.
Current: 1994 968 Coupe, 1987 944S, 2004 VW GTI 1.8T, H-D XR1200
Previous Porsches: 2000 986S, 1974 914 2.0 Blue, 1974 914 2.0 Yellow, 1970 914 1.7, 1985 928S
Previous non-Porsche favorites: 1974 Early Bronco, 1975 Cosworth Vega, 1977 Trans Am 6.6L, 1973 Karmann Ghia, 1983 Supra (turbocharged)
Threads: 19
[quote name='dry664' timestamp='1369331157' post='143021']
After driving for a bit the heavens opened (in the UK, whodathunkit??) and within a couple of minutes the rattle went away completely. Its definitely dampened by moisture. Its worth mentioning that I am getting some water coming in though the hatch pin recievers when it rains, although i find it difficult to see where <img src="/forum/images/smilies/968/whine.gif" class="smilie" alt="" />
If the rain (we don't know what that is in Oregon either) eliminates it, I'd definitely work more on the seals. I've had issues on hatchbacks before and was able to eliminate the noise with silicone spray lube.
As far as water coming in, there appears to be a drain hose attached to the bottom of the hatch pin receiver mechanism. You might pull some rear trim and look to see if that's where the water is coming in from a loose hose, or a cracked pin drain pan that the hose is attached to.
