idle rpm?
What rpm does your 968 idle at?
840 +/- 40 is the spec for the manual trans - that is where mine idles
880 +/- 40 is the spec for the tip
<!--quoteo(post=77970:date=Aug 16 2009, 02:44 PM:name=flash)-->QUOTE (flash @ Aug 16 2009, 02:44 PM) <{POST_SNAPBACK}><!--quotec-->840 +/- 40 is the spec for the manual trans - that is where mine idles
880 +/- 40 is the spec for the tip<!--QuoteEnd--><!--QuoteEEnd-->
Thanks Flash. I'm at 810. I suspected it was a little low (auto).
~Byte~
no worries - easy fix too- before you do it though, make sure everything is off (AC, lights, yada yada)
Flash, How can you raise the idle? You wrote it is an easy fix. This instead of the manual that said something else.
there is a screw on the throttle body - in stock form it is accessed from underneath
I'll have a look for it!
Brian
When I was adjusting, I noticed the throttle cable was really loose. I could almost slip if off the roller. I tightened it up just looser than taunt, is this right?
pretty much - you set it as tight as it will go WITHOUT causing the armature to move, which would consequently raise the idle
<!--quoteo(post=81949:date=Oct 16 2009, 01:06 PM:name=flash)-->QUOTE (flash @ Oct 16 2009, 01:06 PM) <{POST_SNAPBACK}><!--quotec-->pretty much - you set it as tight as it will go WITHOUT causing the armature to move, which would consequently raise the idle<!--QuoteEnd--><!--QuoteEEnd-->
Sweet thats what I did.
Follow up. I set the idle to spec(in park). Well when put in gear, it drops tp ~800? I don't remember what it did before I set the park RPM. Is this about normal?
tips should be set to 880, not 840 like on manual trans cars
<!--quoteo(post=81957:date=Oct 16 2009, 02:39 PM:name=flash)-->QUOTE (flash @ Oct 16 2009, 02:39 PM) <{POST_SNAPBACK}><!--quotec-->tips should be set to 880, not 840 like on manual trans cars<!--QuoteEnd--><!--QuoteEEnd-->
Yep, at idle in park the rpm is just over 900, but when I put it into gear it drops to ~800.
i'll check the tip car tomorrow morning
<!--quoteo(post=81967:date=Oct 16 2009, 03:56 PM:name=flash)-->QUOTE (flash @ Oct 16 2009, 03:56 PM) <{POST_SNAPBACK}><!--quotec-->i'll check the tip car tomorrow morning<!--QuoteEnd--><!--QuoteEEnd-->
Thanks!
i got a chance to check it out yesterday - mine drops about that much too
<!--quoteo(post=82040:date=Oct 18 2009, 02:28 PM:name=flash)-->QUOTE (flash @ Oct 18 2009, 02:28 PM) <{POST_SNAPBACK}><!--quotec-->i got a chance to check it out yesterday - mine drops about that much too<!--QuoteEnd--><!--QuoteEEnd-->
Thanks, my idle still runs a lot smoother while in drive and while coming to stops. I think adjusting the idle has made a big difference.
Sometimes, the car would stall while coming to a stop. The trottle response is a lot better since adjusing the throttle cable too.
Last Post by rl968
04-28-2011, 07:50 PM
Last Post by S_Cal968
01-03-2009, 03:06 AM
