Threads: 137
Put a pressure tester on the system, pump to 21psi, holds pressure fine. Look around and can't find a leak or even a wet spot anyware, everything seems fine.
Go out for a drive and drive her hard for 30 minutes, come back in and the coolant level is down about 2 inches.
Fill it up, test it again, no leaks. Go back out for a drive, come back, down almost 2 inches again.
I'm about to make this thing into a go-kart! <img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" />
Anyone have any suggestions on where on earth the coolant could be leaking...but how can it be leaking when the pressure tester doesn't budge???????
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
Threads: 8
Quick check is the dipstick, if it looks milk chocolate brown you have big problems. Don't run it, the coolant is getting into your crankcase polluting the oil. If it's only going into the combustion chamber you're better off but not by much, probably a head gasket and hopefully not a cyl. head fault.
Brian Wilson, Amazon Green Coupe, middle-aged guy from Boston
Home of the World Champion Red Sox and soon to be four time Superbowl Champion New England Patriots. GO PATS!
Threads: 137
Michael Sorbera
2002 VW Beetle TDI
