[quote name="jmarten" post="182153" timestamp="1518600634"]Tim,
Judd in Seattle here, with a 94 Cab Tip, white, grey top and interior. Really like the color of your car.
Welcome, good to hear about another NW 968 person.
I added the Design 1 supercharger shortly after purchase last year. Did all belts at that time and was worried about the flex damper with the added power. But the Tip is pretty gentle, starting out in 2nd, and IMHO the biggest risky behavior would be shock more than acceleration or normal use, like a full throttle passing maneuver at say 60 mph, with a sudden shift down to 2nd, not 3rd, with a lot of shock to the damper. Ouch.
Anyway decided to not do the damper, and so far so good. I mean it is a separate job from just about anything else, and I will do it if needed, whenever. Famous last words.
We are going to the West Coast meet, hopefully see you there.
Judd
Quote:Yes, indeed .
Also, the tips will vibrate at idle slightly more than the six speeds. ( just a bit more, and not very pronounced but still noticeable, by comparison )
Thanks Judd and Dan,
The Flex Damper has been replaced on my car according to a conversation I had with the shop in SC who did the work. I dont have any paperwork on that though.......
There is quite a bit of vibration at idle in gear, and although the motor mounts were also replaced I wonder if they used the correct mounts for a tip car. More sleuthing to do when I get the car home.
With the 8 of new snow we received overnight I am reminded its still winter here and I am wondering about my plan to trailer the car up. There are three mountain passes around 5,000-7,000 feet Ill have to go over.
Edit;
By the way, is there some trick to using multi-quote on this forum?
Ive had a 50% failure both times I have tried now.
