07-08-2009, 12:26 PM
Been away from the forums for a while - and holy heck... I come back and see Dan's sobering timing belt failure thread.
Ha. Well after a cool 50k (I was asking for it) my timing belt stripped out about ten teeth at the bottom. To save some bucks and to learn a thing or two about the car, I'm taking on as much of the heavy lifting myself as I can - then relying on local racer expertise to recondition my head, get the re-installed cam timing right, & etc.
After two days of work over the holiday weekend, plus a couple of evenings I almost have the head off. That exhaust manifold is a pisser. [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
My car is in the 120K range - so the While I'm In There List is not trivial - I'm trying to keep it as short as possible. New pump, seals, oil separator (see below), and so forth.
Lots of pics to follow.
Commenting on the other thread's discussion of "what's it like when your timing belt goes" I can say it's a much more subtle, and lethal, drama-free failure. The car just stops. In my case, at a stoplight. The engine *does* sound different when cranking trying to re-start - more clangy - the sweet sound of valves clanging on pistons. I initially thought it must have been failed DME. When my A/C compressor clutch froze - *that* was much more dramatic.
Consistent with another poster's experience - the top rear timing belt cover bolt holes were, uh, stripped/corroded/exploded. Weird.
I have some questions for you quys. My cam gears look pretty good. Pads are worn but not scarily so. I'll replace them.
It's usually a mistake to post multiple questions inside a single thread - but this is a friendly group here. Let's see what happens.
First question: The valve cover was ahem.... scary brown. I'm extremely envious of the pristine camshafts posted here by others!~ My mechanic thinks the oil separator is bad and blowing all kinds of doodoo back through the system. Intake manifold interior, injector tips are really gummy. I've used nothing but Mobil1 as long as I've had the car. What do you think?
Second question: The cams are off. Damn. The variocam unit is a muscular little fellow! I need some advice on how to compress the variocam pistons together enough to get the chain off the cams. I've tried squeezing with a vise between two blocks of wood, but it seems to stop with about 1/2" to go - not enough slack to get the chain over the gear cogs.
Cheers,
Jeff in VA
Cheers,
Jeff in VA
(This post was last modified: 07-08-2009, 12:31 PM by apex.)
