Head Lights
[img]style_emoticons/<#EMO_DIR#>/mad.gif[/img] I just had my car in the bodyshop and the front bumper was removed. The first time I turned my lights on, they would not go back down when I turned them off. This has happened before and it was a simple fix, but I can't figure out how to fix them. Any ideas?
since they are gravity fed once the release has been triggered, i would get some tri-flow (not WD-40) and lube up the mechanism, operating it manually a few times to get it worked in there
if that fails, then i would look at the adjustment alignment - there are instructions for that in the workshop manual
Well, my mechanic lubricated the mechanisms and checked for binding. They'll work most of the time, but will stay up 1 out 25 times. He has order a relay($161.41) which he thinks is the fix. Anyone got any ideas or know of a cheaper relay that will work?
bummer - there are a couple of relays that are pricey - obviously check the lower priced sources like sunset
Last Post by snova
12-20-2020, 06:49 AM
Last Post by jferraro17
09-27-2016, 02:37 PM
Last Post by 94SilverCab
04-23-2014, 10:43 AM
