Head light Help
Head lights go up but will not go down without turning them by hand....anyone know whats going on here and how to fix?
Tks
Luke
[color="#330099"]SpeedRacer64[/color]
[color="#000"]100%[/color] Pure Stock 1994 968 [color="#000000"]Blk/Blk [/color] [color="#CC0000"]6Sp[/color]
down movement is electrically activated but gravity operated - likely gummed up mechanisms - very common - soak with tri-flow (not wd-40)
<!--quoteo(post=72864:date=May 31 2009, 12:35 AM:name=flash)-->QUOTE (flash @ May 31 2009, 12:35 AM) <{POST_SNAPBACK}><!--quotec-->down movement is electrically activated but gravity operated - likely gummed up mechanisms - very common - soak with tri-flow (not wd-40)<!--QuoteEnd--><!--QuoteEEnd-->
My headlights don't always go down when I shut them off. It seems if I turn the ignition key back on they drop down. But not always. Can the mechanism be lubed up without disassembly ? I have not taken a close look at the set up yet. Does it have a spring return ?
Rico Suave
after the electric release, they are gravity fed on the down stroke - get yourself a can of tri-flow and squirt liberally on the entire mechanism
<!--quoteo(post=79507:date=Sep 4 2009, 06:48 AM:name=ebarone968)-->QUOTE (ebarone968 @ Sep 4 2009, 06:48 AM) <{POST_SNAPBACK}><!--quotec-->My headlights don't always go down when I shut them off. It seems if I turn the ignition key back on they drop down. But not always. Can the mechanism be lubed up without disassembly ? I have not taken a close look at the set up yet. Does it have a spring return ?<!--QuoteEnd--><!--QuoteEEnd-->
Exact same symptom. I got one stuck in teh up position on the Ortega run and had to decide whether to get left behind while "rebooting" the car, or stay with the group looking like a cyclops.
<!--quoteo(post=79513:date=Sep 4 2009, 11:10 AM:name=rxter)-->QUOTE (rxter @ Sep 4 2009, 11:10 AM) <{POST_SNAPBACK}><!--quotec-->Exact same symptom. I got one stuck in teh up position on the Ortega run and had to decide whether to get left behind while "rebooting" the car, or stay with the group looking like a cyclops.
[Image: attachment.php?thumbnail=6964]<!--QuoteEnd--><!--QuoteEEnd-->
that's funny/ they call that a winker [img]style_emoticons/<#EMO_DIR#>/wink.gif[/img]
<!--quoteo(post=79509:date=Sep 4 2009, 09:57 AM:name=flash)-->QUOTE (flash @ Sep 4 2009, 09:57 AM) <{POST_SNAPBACK}><!--quotec-->after the electric release, they are gravity fed on the down stroke - get yourself a can of tri-flow and squirt liberally on the entire mechanism<!--QuoteEnd--><!--QuoteEEnd-->
Thanks for the info ! I will be on that this weekend
Rico Suave
This is my latest issue - sort of. Headlights went up this morning and won't go back down. I tried to apply gentle pressure and they wouldn't budge. Fuses #2 and 37 are okay. Not sure what mine is, but I am thinking the "electricaly activated" part is effed up.
After a few years of troublefree ownership, I have had several electrical gremlins pop in in the last 5k miles or so. Car is at 185k, though.
Late 94 968. 6 Spd, Black/Black, 17" Cups. Lowered & Koni[color="#FFA500"][/color]'ed. <i> 217k miles and clicking away more every day</i>
Could be for sale if you are interested in a good high mileage car - PM me.
there is a procedure in the manual for correct armature setting - it is possible that this has somehow gotten out of whack - if it isn't in the right spot, the release cannot happen, and then gravity won't take it down
Don't suppose yopu have that procedure handy, do you? I'll try to look through my pdfs at home when I get a chance.
nope - i just keep the manual on the computers and go to it when i need it
<!--quoteo(post=81064:date=Oct 1 2009, 05:12 AM:name=barth7)-->QUOTE (barth7 @ Oct 1 2009, 05:12 AM) <{POST_SNAPBACK}><!--quotec-->This is my latest issue - sort of. Headlights went up this morning and won't go back down. I tried to apply gentle pressure and they wouldn't budge. Fuses #2 and 37 are okay. Not sure what mine is, but I am thinking the "electricaly activated" part is effed up.
After a few years of troublefree ownership, I have had several electrical gremlins pop in in the last 5k miles or so. Car is at 185k, though.<!--QuoteEnd--><!--QuoteEEnd-->
You might try fuse # 16...headlamp motor close
~tom
997 C2S
GMC Sonoma SLS, dd
Miata LS, Cheap Thrills
Acura TL, Wifes dd, zzzzzzz
1993 Red 968 M030, after 18 yrs, gone but not forgotten
Fuse 16 was okay. Realized I had already checked it. Didn't have time to troubleshoot it any more last weekend.
09-13-2025, 07:36 PM
05-31-2023, 04:27 PM
Last Post by MLB
06-03-2018, 02:38 PM
