07-29-2010, 05:27 PM
OK, after living with essentially no lighting in my guage cluster, I decided to take the cluster out and replace the bulbs.....or tackle the relector issue.
After I took the assembly out, I saw that the p/o installed the led lighting in the 3 bulb pods/holders......figure they're either burnt out or just garbage? So I got 3 new bulbs from the dealer (3 watt) and proceeded to pop 'em in hoping for actual illumination! Sadly, nothing, or VERY little light coming up thru to the guages. So I took the cluster out and thought I would check the condition of the 3 'cones' (reflectors) that can wear and cause the chrome to flake off or fade.
For whatever reason, they were all covered in black electrical tape and had NO chrome to reflect anything up to the guage face!? As if installing the led's would have caused too much light, they chose to blacken the reflectors out!?
I then cut out and taped on 3 peices of tin foil (shiny side up (in)) - in the hopes it would solve this problem...but again, very, very little light (I put the new 3 watt bulbs back in)
Then I got to thinking. If someone were to follow the advice (sticky thread explaing how to prep the cluster) - as to how the original coating must be removed to allow the 'chrome' to shine thru, it would seem that those 3 'cones' should be clear - not black (like a dark window tint) to allow any kind of reflection to shine thru and up to the guages! Mine almost look like they are painted/tinted black!?
I'm going nuts having no guage lights at night so any advice is greatly appreciated! Maybe I have to take the led's out completely to allow the new bulbs to do their job? I simply tucked the wires into the bulb holder pods out of the way.....well, for the most.
Cheers!!
Cheers!!
Sold
