05-31-2008, 01:08 PM
If you have fuel smell after filling up, check filler neck for cracks. Remove trunk carpet right side, remove sound insulation over filler neck, remove cover (5screws and two nuts). Gently pry cover off (sealed with weather strip). gently unclamp all clamps attached to the central plastic neck. loosen two lower hose clamps.
BE CAREFUL NOTHING FALLS INTO TANK!!!
gently remove the plastic filler neck. now remove two screws holding on the filler door (outside of car...so you don;t break off the door when repairing)
remove outer metal ring. pull out rubber neck. clean everything and replace with new parts in opposite order. I put upper filler neck in first, then lower hose, then the middle plastic piece, and then fit the upper neck to the plastic piece. lubed everything with a spray of WD40. gently reconnect all hoses (DON'T FORCE ANYTHING AND BREAK IT)
there is a little ball float in the lower part of the plastic piece, DO NOT LOSE IT DOWN THE TANK!!
final step is to replace covers (upper and lower metal covers) Use rope caulk (available at home depot for 3$)
pics inlcude rotten cxracked upper neck and new complete set installed
(This post was last modified: 05-31-2008, 01:09 PM by xrad.)
Sold
