Fuel pump issue
One would assume the stock fuel filter would catch any debris, not sure why and extra filter would make any difference?
The only advantage I could see is removing the stock one an putting in a clear one so you could see if there were any contaminants.
That's why I suggested a postmortem on the old filter. If there is no junk in there then the re-re of the gas tank might be a futile exercise.
Dave
[quote name='DaveN' timestamp='1308943730' post='111720']
Gas goes from the tank to the pump to the filter, so the stock filter is after the pump. There is a fuel screen in the tank that should block most debris from getting out to the pump but it doesn't seem to be working for me. I replaced the in tank screen after the first pump and before the second. I found some black debris in the filter that looks like charcoal, so I need to check the tank next.
Last Post by pdxmike
06-10-2019, 02:40 PM
Last Post by unknown4u
09-29-2017, 02:51 PM
08-05-2016, 08:54 PM
Last Post by DaveN
07-25-2013, 04:30 PM
