Front Running Lights
Both front signal lights go on to the running position when I put the brake on, off when I take my foot off.
This doesn't happen when the running lights are in the on position, only when the lights are off.
Everything else is fine. Anyone seen this? I've replaced all the bulbs front and back.
do your brake lights work normally?
<!--quoteo(post=74903:date=Jul 2 2009, 02:54 PM:name=flash)-->QUOTE (flash @ Jul 2 2009, 02:54 PM) <{POST_SNAPBACK}><!--quotec-->do your brake lights work normally?<!--QuoteEnd--><!--QuoteEEnd-->
Yes.
have you been playing with relays lately?
<!--quoteo(post=74905:date=Jul 2 2009, 04:04 PM:name=flash)-->QUOTE (flash @ Jul 2 2009, 04:04 PM) <{POST_SNAPBACK}><!--quotec-->have you been playing with relays lately?<!--QuoteEnd--><!--QuoteEEnd-->
No
then i think you likely have one of two things:
a bad ground back at the rear lights - pull the carpet out of the rear - you should see a brown wire tied to a screw on the body
<!--quoteo(post=74907:date=Jul 2 2009, 04:35 PM:name=flash)-->QUOTE (flash @ Jul 2 2009, 04:35 PM) <{POST_SNAPBACK}><!--quotec-->then i think you likely have one of two things:
a bad ground back at the rear lights - pull the carpet out of the rear - you should see a brown wire tied to a screw on the body<!--QuoteEnd--><!--QuoteEEnd-->
I'll check that out thanks.
lol - i just realized that i didn't tell you about the second thing
i suspected a possibility of a faulty relay or flasher
i'd go with the ground though
Got it, used CRC cleaner on all bulb receptacles and wiring connections, including the ground.
So don't know what fixed it, but glad its over.
yeah - it seemed like a connection issue, and given that it hit both sides, i figured the ground - glad it's worked out
Last Post by schwarz968
08-01-2014, 03:56 PM
Last Post by Cloud9...68
03-22-2014, 05:03 PM
Last Post by mbardeen
06-21-2012, 08:42 PM
Last Post by PhilG968
02-07-2012, 11:17 PM
Last Post by sydneyman2007
05-06-2010, 05:33 PM
Last Post by DewaneP
10-19-2009, 02:42 PM
