05-29-2013, 11:59 PM
After I bought the car, an early inspection of the engine compartment revealed soot where the engine block meets exhaust manifold at cylinder 4 (back of engine). I thought there must be a leak in the manifold gasket, will look into that before summer, and before the 9 hr drive to Parade in Traverse City.
Its in the shop now for clutch/flywheel replacement (wow, badly worn, I think POs did not know how to drive a clutch, because I'll be putting in the 3rd one!)
Anyway, with the front of the exhaust out, I can look up into the manifold, and the port from cylinders 1,4 is black with soot, but the 2,3 port is clean and silver.
So, a couple things I'm considering:
1) probably is a manifold gasket leak at cyl 4.
2) could the soot inside 1,4 exhaust be telltale of a dirty injector? and do these engines have independent injector control, or are they all set to inject the same? I'm considering just sending all injectors out for clean&flow test. Pelican has a crazy price for new ($637 each, but Marren only $95, I would consider buying a new set of injectors for $400, even if only for spares)
Anything else I'm missing?
Thanks!
Thanks!
(This post was last modified: 05-30-2013, 12:03 AM by MLB.)
