Exhaust gasket removal
I had to pull my exhaust headers to repair a leak.  I can't figure out how to get the 4 "O" shaped metal exhaust gaskets out of the head. They get crushed into place when the headers are torqued on, and there is not much access. If anyone can pass on a trick or technique to pop these out, I would be very appreciative.
Those are a PITA, no question about it. I have a small stylus with a 90 degree bend at the end that looks almost like a dental pick that works for getting those out. You can get a set of them at your local Harbor Freight for a few bucks. That's the only tool I have found that has the angle and the thinness to get between the header and the crush washer. Once a space opens up, a thin screwdriver can do the rest.
Good luck!
Matt
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
11-09-2024, 11:40 AM
12-30-2018, 09:32 AM
Last Post by WJH
06-25-2014, 06:27 PM
Last Post by kwikt
06-10-2014, 08:17 PM
05-31-2013, 05:22 PM
