Threads: 65
Looks like varicose veins. Of course it is an old car!
(sorry, couldn’t resist)
'93 Horizon Blue Metallic Cab
'58 Triumph TR3A (sold)
'06 Lexus RX400h Hybrid
Lots of guitars
Threads: 45
I will have to dig out my camera and have a look, my car is at 165K
Threads: 45
165,667 miles, but Im way short of my friends iris blue sport at 225,000 miles
Just need to find a working laptop now, all been unused for the last 2 years now the batteries are all dead
(This post was last modified: 09-06-2022, 12:29 PM by
Waylander.)
Threads: 45
The hunting is caused by wildly swinging signals from temp sensors, air flow, idle speed, they all try to compensate for each other,
Air leaks in the ICV and that also gummed up cause a lot of the issues,
Start by checking the values of the small blue temp sensor under the top hose, then clean the MAF with any kind of carb cleaner, just do not attempt to touch the fine hot wire, then finally dismantle the ICV and replace the o ring that seals the top from the bottom, and some silicone around the electrical plug while giving it a deep clean and lube
That should sort it out
Threads: 45
It leaks around the cable plug, and there is an O ring that seals the body to the base, mine was in about 10 bits on dismantling
