10-26-2009, 06:02 PM
Allrighty, I have been having some electrical issues of late. Here are the basics:
My initial electrical issue was when I had a short somewhere inside the bodywork of the two wires going from the hood latch micro switch to the fuse box. I was under the hood and noticed some smoking at the wires. I tried to separate and reinsulated the wires as much as I could get access to them, but was unable to. At this point I disconnected at the switch and then cut those two wires where they enter the fusebox.
Since then I have had the following electrical issues:
1. Blew a fuse to the wipers twice
2. Slow battery drain on two occasions (dead after 6 days)
3. Climate system fan remained on with key out.
4. Power windows work with the key out
5. Wipers work with the key out
6. Headlights stay in the up position. Can manually lower with the knobs on the motor, cannot push down. (I think this is unrelated to the other problems)
7. Airbag light is on (this happened when the battery died the second time and I had to jump off)
To remedy the fan situation, you can do three things:
1. Remove the fresh air blower relay
2. Remove fuse #8 (interior lights)
3. Remove Fuse #24 (wipers)
4. Unplug resistor in cowl area
I suspect that when the short to the hood latch occurred, I had some other wires get shorted together which are now supplying constant 12v to the problematic interior pieces. This could be under the fuse panel or elsewhere.
Let me know if you guys have any ideas. Thanks!
