[quote name='Harvey' date='Jun 8 2005, 06:13 PM']Someone suggested an interesting approach...since my CEL is not working...why not just move the DME wire for the CEL to another dash light...and count the fault light codes on that other dash light...saving me from pulling my dash right now. That's better than my idea of hooking up a small light to the wire for the CEL as it comes out of the DME controller.[/quote]
I'm not quite sure how you would do it, but remember, when the ignition is turned to on, all lights are lit, so if you use a different light to test the "check engine" codes, you will have to disconnect the primary power source to that bulb. You might just be better buying a "test light pen" or something.
