Design 1 Racing Stage 2 Supercharger Kit
When I first put the supercharger kit together, I knew that the header would not be able to be used, due to its need for more fuel. We knew this based on what happened in normally aspirated mode, and how much fuel needed to be added for that application. It would only be worse supercharged. The injectors were already maxxed out up top, and there was no room for more fuel to be added. Adding pressure with an AFPR didn't help, and in fact made things worse, as it was like squeezing off your garden hose. Sure, you get more pressure, but you get less flow, and flow is what it is all about. So, the decision was made that the header could not be used in conjunction with the supercharger kit. It was disappointing and complicated for some of the guys, but I was quite adamant about this, as I wanted to keep within the design parameters, which included no injector change, no fuel system changes, and keeping the price down.
Still, Pete being the nut he is, was determined to see if it could be done. So he stuck in some bigger injectors on one of the cars getting the kit. While they provided more fuel, and after some fiddling, the mapping of one of my chips was fairly close in the midrange, it still left some areas that were real problems.
This painted me into a bit of a corner, as I did not want one of my kits out there having problems, and it was sure to do that. Yes, the car is quite fast, but it still isn't right, and there are very real problems with the tuning of it.
Knowing that I needed to handle this one way or another, I installed the header on my car, and sure enough, not nearly enough fuel, but I could immediately tell that it flowed better, and ran freer up top. More power was clearly available.
This led me to try what Pete was trying, and then get in and see if I could tune it. I plugged in the larger injectors, complete with the mod that Max does to them to make them fit. They however did exactly as I expected, and flooded things too much down low, and at the same time made things too lean off idle when you stabbed it. This was all due to the increased flow of the header, and the velocity of the gasses over the O2 sensor.
The cold start was also insanely fat. So rich in fact that it filled my garage with black smoke. Not good. This would create all kinds of long term problems, especially on a car that was not driven often. Ring wash was certain to happen, and the oil would quickly become fouled with fuel.
Across the board it is too rich, and needs to be cleaned up, but that is manageable, and I would need to spend a couple of days mapping that out.
The bigger and more dangerous issue was the upper end was also still lean. This means having to increase fuel even more, meaning even more clean up down low.
Problems now identified, I moved on to trying to solve them.
The cold start issue persists, and looks like I cannot resolve it with the facilities and resources I have. There are 143 maps to control the fuel and timing of the engine, some of which control the cold start. The problem is that there is no way of knowing which ones interact, and how. I would need to go into a lab to find out.
To tune the rest of this, I will have rework the rest of the part throttle mapping, and then the WOT mapping. When that is done, I get to come back and do a final round of part throttle mapping. Then I get to go and drive it and record the temps and such and make sure it is reasonably safe, before I can then call it "done".
In the end, I think I could get it, but it will not be clean enough to pass any sort of emissions tests. I just don't have the facilities to generate the conditions needed to map for all conditions, which would be needed to pass emissions. It will run fine, but will probably be too rich to pass. The cold start issue would remain though.
The application gets a bit dodgy as this becomes a very real problem for any car that would sit between drives. The rings would contract, and the fuel would end up in the oil while they were warming up to expand again. This would mean more frequent oil changes, and cold-blooded starts. If you drove the car on a very regular basis, this would be lessened, and it would be very much like having an older hot rod. It would be tons of fun to drive, but a bit temperamental. This consequently will really be a track application.
To give you an idea of what would be involved to get more power:
1. It will require the header from RS Barn (see their site for pricing).
2. It will require the AFPR, which will then have to be set to a specific pressure (so you'll need a gauge to do that or have a shop do it).
3. It will require the RS Barn cat-back or very close facsimile (see their site for pricing). A system that is too free flowing will not run right, nor will one that is too choked up. It really needs to flow about the same as the RS Barn system. Big pipes, or twin pipes, or gutted OEM stuff won't work.
4. It will require the modified injectors (see RS Barn for pricing).
5. It will require the new chip for this setup. (likely to be $350)
6. You absolutely have to have a functioning O2 sensor in there.
7. Under no circumstances will this pass the visual inspections or the emissions inspections of any state that has them.
8. You will likely have to sit and warm up the car before you can move, taking about a minute.
9. You will likely not get more than 3000 miles from your oil.
10. Your fuel economy will drop about 20% from what you would get with a chipped car, and about 40% from stock.
If I proceed, I will only be selling the chip, and the rest will come from RS Barn. If you have to buy it all though, you are looking at about $3k.
The one thing I do know is that I will not be responsible for any engine damage as a result of running this setup. I still think it is less than a stellar idea, but I also understand that some people just want more.
Boost will not be increased. I already tried that. The intake temps are already at the safe limits. Increasing boost, even 1 pound, would require an intercooler and a complete remap.
Power increases should be a good 15hp up top and at least 10 ft/lbs across the board from just under 3k on up. It could be a bit more. Of course I would provide dyno charts to show everything.
Before I go any farther with this though, I really need to get a handle on just how many people would even be interested. The time investment and out of pocket cost is significant. I won't be running this on my own car, so my motivation is not there if nobody wants this.
I am interrested in a AC delete version. The market for this could be reasonably large since many track day enthusiast will have cars with no AC. I would think that these are more common in Europe.
I like your bang for the buck reasoning with the original kit. The only question in my mind is that our fuel quality is better with 98 readily available (think this corresponds to 96 the way you rate things over there?). From what I understand from the thread you already tried this or considered this.
With the power of the original kit I would only be interrested in anything which increases reliability under sustained hard track driving.
All the best!
Torbjörn
there is no way for me to work out an AC delete version without having one to do it on, and i'm not taking mine apart - to do it with a complete delete, the belt arrangement and mounting would be entirely different - to make it work on the existing setup, basically i would need to somehow stick a pulley the same size and location as the AC pulley in there in place of the AC pulley - again, without a car on which to do it, there is no chance of that happening
you measure RON and we measure RON+MON/2, so 98 for you would be 93 for us
to clarify about the first post, i didn't mean to paint a picture of doom and gloom, but i wanted to be clear that while there is more power to be had, it is not without compromise, and thus far the one other car that has the header on it is not really dialed in, and needs more work before it can really be driven - i'm sure it can be done, and it won't be all that hard to get it to a point where it is safe to drive, but there will always be a bit of compromise in the setup - that may be fine for some, but not for others - that's a subjective decision that you have to make for yourself
personally, i am removing the header and going back to the OEM header (and selling my freshly ceramic coated header, as well as the new injectors) - i never really liked the sound of the header anyway, though the power was quite nice - but, since i have to undergo emissions testing, and i am very unwilling to deal with the cold start issues, i will just learn to live with the fact that i was unable to have it all
as for the timing of the release of a "kit" that would make this work, that depends entirely on the interest level - if it's high enough, i can do it in the next few days - i have time while i await the OEM header coming back from the ceramic coater and await the arrival of yet another set of exhaust rings, studs, and nuts
if the interest isn't there, then it will wait at least until the snow melts, and the other car that has the header on it can be taken back to the shop for the completion of the setup - it has to go back there anyway, since it is too lean above 6k, but how far the tuning goes will depend on whether or not it is to be repeated
Sounds like a lot more money for little gains. I would rather stay with the plug and play SC kit and spend that extra money on making the engine perfect... Just my thoughts, my car also is a DD, so it doesn't sound like this kit would be right for me.
Sounds fun though, I would be willing to drive someones car with this kit on it... <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
yeah - if you had to buy it all, it is quite a bit for not that much increase
that being said, a number of people already have the header and cat-back, so that cost goes WAY down for them, but actually goes up if they wanted a supercharger, and had to go back to OEM to do it
consequently, i see the reasoning for developing the tuning and such for that scenario
i'm just not sure, of the people who already have the header and such, how many would also want to supercharge, AND would have the money, AND would be ready to do it almost imminently - i'm guessing maybe 2 or 3 - but, maybe i'm wrong
i am all but certain that this next batch of kits is the last for at least a VERY long time, so i thought i would try to make it available to as many as i could - i am definitely not going to be doing any more development of any more versions or anything for the kit once i get my car done in the next couple of weeks, and get the tip kit done about the same time - once i open it up, and take those orders, that's it - i'm hanging it up on kits for probably at least a year, and by that time, i may have moved on from providing parts and stuff altogether - this is only a hobby after all, and once my car is done, i put it in the stable and move on to the next car i want
so, this is really it for anybody to have any chance of going farther with any help from me
Bob as you I don't post much anymore but do still lurk.
You made it quite clear early on that the s/c was for a basically stock car (with cat back) so I was not looking for you to have to tune for the header, etc when I had Pete install the s/c with my existing mods. I told you on the phone weeks ago but you can print this for your records if you wish- I will not hold you liable for any damages done with my setup nor would I have done so even if I did not have my mods (not sure how anyone could hold you liable when modifying their car). I'll take care of getting my car tuned in the next few months when I have more time. After driving a s/c car without the header and with my butt meter likes the header version much better so I'll see what I can do to keep it that way. It's certainly not for everyone but I figured my car, my dollars and my risk.
As for MPG- it is not really a concern of mine but I did get mid 20s driving 80-90mph for 250+ miles of highway driving with the s/c and that was with me screwing around a lot enjoying the acceleration in 6th gear. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
If I am unable to get a decent tune done and have to remove the header I will be removing the s/c and selling the car and either selling the s/c or installing it on the wife's car. I knew this when I bought the s/c and waffled over installing it or selling the car for several months. I decided to take a shot and see what it was like and that was my decision alone so no worries on my part, it's my money to waste and I knew that going in. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
I, for one, will be sticking with a stock "Batch 2" SC. Reliability and repeatability are the keys here for me. For those small amount of gains (hp/tq) it's not worth the worry or possible headaches.
mark - no worries - your car just pushed me into doing this sooner than i anticipated (which is what i told you when we spoke) - it's not like i never wanted to get into this, i just wanted to wait until a full summer and winter had gone by on the stage 1 kit, before i jumped into stage 2 - but, as solid as stage 1 has been, i have no concerns, and can move forward
i will have the time this next week or two to tune for your setup, but want to be sure that i am not spending that time for just one car, when there are other things for me to be doing - sorry, and i'm not blowing you off, but i do have to stay focused
obviously i am in a unique position to do the tuning, as nobody else knows the kit like i do, nor is anybody else who knows how to tune the ECU willing to do it, as it requires live tuning, in the car, as well as dyno tuning - i also own the exclusive right to the code i had written for a crucial map needed for this to run right, and i'm not sharing it - for somebody else to get to the point where i am would require a LOT of time and effort, and i just don't see that happening, and certainly not for any reasonable fee - pete is not ready to do it, and probably won't be
so, i'm happy to do it, but how far i go, and whether i do it here or remotely depends on how many cars would need it
i wish that pete had done a dyno run, even shutting it down by 6k before it went lean, so that i had an estimate of the output gain - that alone may spur me on to find out what the gains would be, so as to help others in the decision
As much as I would like to see more power, this doesn't sound like the kit for me. I admittedly don't know much about how all of this works, but I think what I really want is an intercooled kit with more boost. All of this being CARB legal and good to use for a street car. I know, not going to happen.....but my car and my wallet are ready given the chance. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
lol - nope - i'm done making new stuff
i am finally getting to the CARB thing -too - sorry for the delay - i can't get over how crazy it has been, and this sidetrack on the header project really messed me up
I appreciate your detailed write up. Few developers keep their customers as involved and informed as you do. Great work. We benefit from your dedication <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />.
Although stage 2 isn't for me, I'm very interested in Batch 2.
gather your beans - i'll be opening up the gates soon, and once that one is done, i'm done for a LONG time - there are already just about enough orders to run the batch - it's really close - once i get the tip tuning done, i expect that to fill the rest very quickly - i will run what i need for batch 2, however many that turns out to be, but not any more
my guess is that i will be done taking orders by the end of january, with delivery by the end of february - it's going to go much faster this time, since all the changes are already done
If you plan to sell out batch 2 that quickly, would you consider making it a bit larger if there were interest?
yes - i don't know what the quantity will be yet, but it will be determined by the prepaid orders
the only reason i haven't started taking orders yet is that i don't want to be hanging onto people's money any longer than i have to
Flash,
Count me in for a standard kit. Looks like the camera I wanted will have to wait for a little while.
Craig
back to the subject of the STAGE 2 kit (not the second batch of STAGE 1)
it looks like there will be a STAGE 2 "kit" - it looks like a reasonable compromise of conditions can be struck - this was quite the challenge - as it turns out, we are going to be doing the tuning of this bi-coastally - it should prove interesting to say the least
this is really a track application - it will not run clean enough to pass any emissions tests, will not pass any visual inspections, and will run richer than what we would like to see on a street car - for track though, this will work very nicely and open up some power - we should have dyno results in a couple of weeks
it will be an amalgamation of a few things - pricing to follow soon:
RS Barn header, cat, and cat-back (which you may or may not already have)
a bolt on modification for the header (available from RS Barn)
new set of modified injectors (available from RS Barn)
AFPR (available from RS Barn)
Design 1 Racing STAGE 2 chip
to be clear, this will allow those with a header to be able to run it - again, it isn't really perfect for street, but isn't horrible either, if you are lucky enough to live where you don't have emissions inspections - it is a bit richer than we like to see, and nothing can be done about that - again, not horrible, but plan on changing your oil every 3-5k max
you will absolutely need to run an O2 sensor
any cat-back must have approximately the same flow characteristics of the RS Barn cat-back - this is critical to the tuning programming working properly - if it's too big and flows too fast, it will run lean up top and probably have off-idle issues as well
this setup will be purchased separately from the supercharger kit, and will require no changes to the supercharger kit itself except the chip
How about RS barn sport cams and high capacity injectors to suit these + a ported cylinderhead (in the car now)? Good thing or to be sold on e bay after a mod?
//TL
well................
the short answer is that my tuning will not work with the cams - not sure about the injectors, as i don't know which ones you have - minimal porting will not cause a problem - major porting would - if the head was shaved to bump compression it would really mess with things
Will check on compression. Given that I find a rollign road and someone good at mapping will the cams be an advantage with a Supercharger or are optimal cam profiles for SC cars different?
//TL
05-30-2021, 01:23 PM
Last Post by rclarkdavis
12-30-2018, 09:08 PM
