Dashboard rattle mystery...any ideas?
Since I purchased my '94 968 cab a couple months ago, I haven't been able to find the source of an annoying dashboard rattle that occurs when the car is driven over the sharper bumps. It sound like it is coming from around the instrument cluster area, so I removed the trim ring and checked to see if anything was amiss...found no loose anything, and I secured some cables just to be certain. I've looked underneath the dash and found nothing loose, in fact I'm amazed at how tight all the stuff is under there. Any ideas about where to look? Should I remove the instrument cluster...anything there to look at? This is driving me nuts! [img]style_emoticons/<#EMO_DIR#>/wacko.gif[/img]
the dash itself is known to rattle in a "clock clock" sort of sound - it is not attached anywhere, and is only held down by the windshield - i ended up running some weather stripping under there to quiet it down
the vents are also known to rattle - no real solution to that one
lol - adding the upper and lower braces, as well as the rear chassis brace is known to resolve most rattles and squeaks from the car, but adds them from the wife
HA! Flash, thanks for the advice. The sound is almost like a box of loose coins or marbles inside the dash. Really preplexing. Any way to test to see if it is just the whole dash? Where did you run the weather stripping? Sounds like this is a "feature" common to these cars, eh?
i ran it underneath the dash - i installed it while the windshield was out - you could try cramming it between the windshield and the dash, but be careful not to cram too much in there, as it could push the windshield up and out
Last Post by tamathumper
07-17-2011, 04:07 PM
Last Post by Anchorman
08-08-2006, 10:18 PM
Last Post by SILVY968
02-10-2006, 12:57 AM
