Compression test standard procedure
the rule of thumb is to crank it until it stops increasing, and to do the same on all cylinders - 8 should be fine - i know that at 4 cranks i get the numbers similar to what you have (180ish) - at 6 i bump up to around 190 - another 2 and she gets pretty close to 200 - no increase beyond that
Agreed on a great thread - busting out my compression guage for some fun.
agree with Flash above. or I just count 4-5 seconds in my head while cranking
I agree as well; I used eight cranks because I didn't have an assistant doing the cranking, so I couldn't see the gauge while I was in the driver's seat turning the key.
My engine was rebuilt aprox. 6000 miles ago, heres my numbers for reference.
Wet or Dry DRY
Date 04-Dec-08
Oil Temp less 50C
Time cranking 10 sec rev
Outside Temp 4C
Variables 5Min startup
Oil Temp 10W-60 mix 5w40
PSI/BAR Cylinder 1 Cylinder 2 Cylinder 3 Cylinder 4
200/13.7 198/13.6 180/12.4 193/13.3
Wet or Dry DRY
Date 07-Dec-08
Oil Temp 95C
Outside Temp 4C
Variables 40 Miles drive
204/14.1 205/14.2 210/14.5 210/14.5
210 - wow - i am only a touch under 200 - looks like i may be due for a valve job - woohoo!
Congrats on the solid readings, but ouch! for me and my anemic-sounding readings in the 170s. I'm holding out hope that my lower (but uniform) readings are due to gauge-to-gauge variations. That's my story and I'm sticking to it. On the other hand, it does make for a good excuse to ship the head to Pete for one of his fancy rebuilds. Might as well get the cams and exhaust while I'm at it, right?
YEAH YEAH - THAT'S IT!
Well, for me i had a chat with Pete before the summer n i followed Pete's advice regarding the Cylinder Walls, i didnt bored out , i just deglazed them ,then new rings and a Stage 1 rebuilt head from RSbarn with Competion valve job. Also break-in of the engine was done lets say not in a conservite way <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" />
Bear in mind that i also think those numbers are a touch on the high side. It could very well be that i didnt time the cams right,a touch on the advance could do this. but then again the engine doesnt ping and i saw temps in the south of Spain up to 47 Celsius <img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" />
Here's a list of all the Mods:
Not sure if some dont affect the readings in this way.
List of Mods
Porsche 968 Cabrio w LSD (220) 1994 MODS
Engine Fully Rebuilt Aug 2008
Compression numbers HOT
204 205 210 210
After 10 days rebuilt engine still did 4500 Miles in less than 5 weeks( gotta love the 968!!)
RS Barn Performance Head Stage 1
RS Barn Performance Cat Back
RS BARN Custom Performance Chip Stage 1
RS BARN 968 Lower Chassis Brace
AC Deleted
CS 1 Fan with Shroud
Hyperco Front Springs Progressive (orig 356 mm vs Hyp 310mm)
KLA SwayBar Support Brakets
KLA Strut Brace
KLA Rear Sway Bar Drop Links
Bored Throttle Body to 71mm w Knife edged Butterfly DIY
Throttle Body Coolant Bypass
HD chain for VarioCam Tensioner + New oil valve
968 Engineering Airbox Modification w Trim Rings
K&N Air Filter
NGK Iridium Spark Plugs
Magnecor Plug Wires KV85
New Sachs Clutch Kit w LUK DMF
Stuttgart Shifting Block
Tranny filled w 50% RedLine ShockProof n 50% Redline 75W-90
Cubby Gauge Panel w Vaccum,Oil Temp,A/F gauge
TechArt Rear Spoiler
FibreGlass Front Wings
968 Turbo RS Bumper Replica
Porsche 968 Turbo Front Splitter
Porsche M030 Sway Bars
Poly Bushes front and rear
Goodridge Brake Lines
Zimmerman Cross Drilled Rotors
EBC Red Brake Pads Front and Pagid in the rear
Ferodo 5.1 Brake Fluid
15mm Spacer Rear Wheels
Porsche Turbo I 18" Wheels with Kuhmo ECSTA MX (Summer)
Porsche Sport Classic 17" with GoodYear GSD3 F1 (rest of the year)
Porsche CS Steering Wheel
Motul 300v 15W-50 or Shell Helix Ultra 10W-60
ATF 6 on PS
Cabrio Hood Mod
4-wire Lambda O2 Sensor
CEL Light Mod(engine fault code reader)
Anti-Hijack Imob.
Cobra Alarm System
GPS\GSM Locator
Focal Speakers adapted to option M490
Sony Head Unit
Alpine 4x50 Amp
Some videos on youtube
http://uk.youtube.com/watch?v=3AX4D2bTX-4
http://uk.youtube.com/watch?v=01kdnlwXM80
http://uk.youtube.com/watch?v=5f5P042x6Ms
Last Post by Lear35A
08-26-2013, 06:25 PM
11-01-2012, 08:56 PM
Last Post by Anchorman
04-19-2010, 01:53 PM
Last Post by rhill5371
12-28-2008, 02:11 AM
Last Post by kwikt
11-25-2007, 08:25 PM
