Threads: 3
<!--quoteo(post=74657:date=Jun 27 2009, 06:43 PM:name=S_Cal968)-->QUOTE (S_Cal968 @ Jun 27 2009, 06:43 PM)
<{POST_SNAPBACK}><!--quotec-->If I recall the AB light is in parallel with the CEL. Disconnecting the power to the AB light has no affect on the CEL, [if the blub blew out it would be the same electrically].
Whether the AB system is still functional is unknown. It would be nice to find out if *all* faults disable the module or is it limits to specific faults.
Someday I'll get mine corrected...
BTW, the wire is yellow/red, in position 6 of the T41 connector [see wire diag. 97-117].<!--QuoteEnd--><!--QuoteEEnd-->
Yes that is the same wire that I disconnected, it is YE/RE after T41 (on the cluster side) and WT/BK on the airbag module side.
I'd like to think the stored codes that I believe the nag is whining about do not disable the system like actual faults would.
-Joel.
Joel Frahm
1987 928S4 Diamondblau/Blue
Threads: 56
Am I correct in assuming that the correct way to deal with the ab light is to install 3 ohm resistors in lieu of the airbags (if removed) and then clear the light with a hammer (not the carpenter one although it might work too
)? And despite doing it in the correct way then light can still come one due to anomalies in the system?
Threads: 13
<!--quoteo(post=76623:date=Aug 2 2009, 08:06 AM:name=firefish)-->QUOTE (firefish @ Aug 2 2009, 08:06 AM)
<{POST_SNAPBACK}><!--quotec-->Am I correct in assuming that the correct way to deal with the ab light is to install 3 ohm resistors in lieu of the airbags (if removed) and then clear the light with a hammer (not the carpenter one although it might work too
)? And despite doing it in the correct way then light can still come one due to anomalies in the system?<!--QuoteEnd--><!--QuoteEEnd-->
Yes that is correct!.
regards Ritchie
Threads: 3
If you have removed the airbags I cannot imagine why you would bother putting in resistors and resetting the system. What you are doing is allowing a system that you have removed the important parts of and does not work to pass a test so it can tell the cluster it is working. At that point, who cares? Cut the airbag warning wire to the cluster or maybe even remove the airbag module itself. Otherwise you still get an airbag nag if you have battery problems or fool with the cluster, but no airbags to protect your noggin in a crash, so you get the downsides but not the upsides.
-Joel.
Joel Frahm
Threads: 13
same as in europe, they will inspect the systems in the nearby future if the car is equipped with it.
So the resistors must be placed instead of a working airbag.
But for me the mainreason is to eliminate the big ! and I hate that some elements that does not work on a car where I paid for.
Threads: 3
<!--quoteo(post=76717:date=Aug 3 2009, 11:17 AM:name=flash)-->QUOTE (flash @ Aug 3 2009, 11:17 AM)
<{POST_SNAPBACK}><!--quotec-->you would do this because it would otherwise throw a fault code, making it more difficult to diagnose other issues, since you would have to get past that one to see the others - also, cutting the wire to the airbag light does not eliminate the "!" - you definitely do not want to cut the wire to that, as it would preclude the ability to know that you had another fault
for $3 why not eliminate it as an issue? sure, you could still trigger it if you did something dumb (as i have done in the past), but the idea of not having the big warning light is potentially dangerous<!--QuoteEnd--><!--QuoteEEnd-->
Cutting the wire as per this thread eliminates the '!' light as caused by an airbag fault. You lose the '!' and the 'Airbag' nags, but you also lose the airbag test indication at startup. The '!' still works for the other warning indications.
If the airbag faults are still visible to the Hammer, as I suppose they would be, you could just ignore them when you run the diags with the Hammer, but diags with a Hammer are not that common at this stage in the 968's life.
With the wire cut, the state inspection would still be a problem, I would not be inclined to try to game them (or disable airbags) myself though.
-Joel.
Joel Frahm
Threads: 3
<!--quoteo(post=76741:date=Aug 3 2009, 03:34 PM:name=flash)-->QUOTE (flash @ Aug 3 2009, 03:34 PM)
<{POST_SNAPBACK}><!--quotec-->it's not the hammer that i was concerned with, but rather the blink test - at this point in the car's life, this is something that should be done on a fairly regular basis - a number of the faults do not trigger the warning indicator (for example the variocam) - that process would be complicated by having the airbag code constantly present, as it shows the faults one at a time<!--QuoteEnd--><!--QuoteEEnd-->
So... if you clip the wire and you have a stored airbag code, you get the airbag code every time you do a blink test. But you could reset that code with the hammer and hope it never comes back. If it does, no big deal unless you do another blink test. At that point you either ignore the airbag code or get it reset.
If you fake out the airbag system and then reset the code, then you have to hope it does not come back due to a battery issue or cluster work or some sort of airbag wiring fault because then you get the nag and the '!' until you get it reset using the Hammer.
Option 1 at least means you never need to hunt down a hammer unless you are really freaked out by the airbag code from a blink test...
But I thought the blink test was just for CEL fault codes and unrelated to these other systems? I guess I can check later on.
http://www.durametric.com/porsche968faultcodes.aspx
-Joel.
Joel Frahm
