[quote name='RickP' post='32003' date='Mar 6 2007, 02:58 PM']Ok, I got a bulk pack of Dynamat and used 6 1/2 18x32 sheets in my coupe. Did the spare tire hole, both bins, and by reaching through the speaker holes in the back seat, did the wheel wells as well as the panels behind the speakers. Porsche had some stuff there already, I just put the dynamat on top.
Interesting results. Using a RadioShack digital sound meter, the pre-dynamat numbers were, Idle=69DBa. 30mph in third=73 DBa. 70mph=75DBa. After dynamat numbers were, idle=68DBa, 30mph in third=73DBa, 70mph=75DBa.
In my reading online, as well as comments by Flash, I knew that Dynamat is effective on mid and high frequency sound, and not on low frequency sound, and my next numbers confirm that.
Pre-Dynamat with the car idling I set my radio level to 73DBa. At 70mph it could not be heard over the din. Turning up the radio until the meter read 78DBa made the radio listenable, although not really enjoyable.
Post-Dynamat, set my radio level to 73DBa and it was still listenable, and enjoyable, at 70mph. The road rumble was still there, 75DBa worth, but it's frequency did not interfere with the music. Apparently the frequencies that did interfere with the music were removed by the Dynamat.
Maybe SheetBlok Sound Isolation Barrier is the answer to the road rumble, maybe I'll get some and find out. Haven't decided. Interested to hear how cavity filling works, as that would be cheaper.
Oh and yea, from inside the car the exhaust does sound deeper.
Rick[/quote]
Rick,
Great to get actual numbers. It may not seem like 1 or 2 dB is not a big deal, but remember that 3 dB is double the power. This means that if you add twice the speakers and amps to the car you will see the meter go up 3 dB. A reduction of noise of 1-2 dB is 33-66% decrease. The "ear-o-meter" says mine driving experience is better.
Dynamat has 2 more steps to increase the isolation of sound and the transfer of acoustic energy. It might be easier than sheetblok as the sheetblok material does not come with an adhesive backing.
Brian
[quote name='flash' post='32012' date='Mar 6 2007, 06:15 PM']yeah - that's pretty much what i expected in a hardtop - i have a whole different set of issues in my cab
in a cab, i think the stereo image would remain similar regardless - in a hardtop, i would expect that decks with time alignment would need to be readjusted to compensate for the change in internal reflection
worth doing though, even in a cab, and i probably will to some degree, just to improve the stereo
lol - though it likely really makes little difference with the top down, so i don't know why i am bothering, besides having completely lost my mind[/quote]
flash,
Got to ride with the top down yesterday and there is a difference with the Dynamat in the trunk. Road noise and general sounds coming from the back end of the car seem to be muted, although it is only the high freqs. The "tinny" metal sound when running on imperfect roads seemed to be diminished.
Brian
