Cabriolet window
Has anyone had a small x shaped slit in the plastic , upper passenger side of the window. It looks like it occured because the way the window folds when the top goes down. Possibly a previous owner put the top down when it was too cold?
In our former Z3 yes the plastic windows do get fragile and tend to crack where they are folded.
which is exactly why i lay a towel down over the window before i drop the top
they even make pillows for this very problem
it does mean you have to use the boot cover, which you should anyway
My top window has a small (maybe 3/4") split at about the 10 o'clock position on the driver's side, very near where the window is sewn to the top. It's been there since I purchased the car a bit more than two years ago. I've been careful how I fold the top (but not to the point of a pillow or towel) and it has not gotten larger. I've thought about trying to fill it, but haven't figured out what to use.
I keep a large beach towel in the cubby and roll in length wise and put 'between' the window as it folds down, also helps keep the plastic from rubbing together and scratching.
Before I replaced my window I used a product called VLP. I was very pleased with the results. Below is the url:
http://www.plastidip.com/consumer/index.html
Ed
Thanks - I'll get this and give it a try.
I know it's a little off topic, but if anybody's interested I saw a message on the Pelican site that somebody is selling their entire cab top for around $600...and I think that includes motors, too.
I don't have a cabrio, but it sounds really inexpensive!
Jason
Thanks, I'm glad to hear that with pampering the split will not get larger. Anchorman, If you try VLP let me know how it works . I am hesitant because it may make the defect look worse.
if it gets really bad, and nothing seems to work, a new top, complete with a back window is not that expensive - around here you can get it installed for about a grand total, including the new top itself
call robbins - they are the original manufacturer of the top
[quote name='edsteve' date='Jul 6 2005, 05:33 PM']Before I replaced my window I used a product called VLP. I was very pleased with the results. Below is the url:
Ed
[right][post="6967"]<{POST_SNAPBACK}>[/post][/right][/quote]
I could not find the VLP product, even at Home Depot (retail supplier on VLP web site) but ended up with good old Elmers (!) clear vinyl glue. I created a few samples and it cured well - clear, rubbery, flexible, and REALLY strong. I had a 1.25" tear on the PS right at the edge of the canvass where it starts to curve downwards. With the top up, the tear would gap and open up about 1.5mm - so I released the top locks to relieve the pressure, used a little clear tape to pull the gap a little closer together, to provide a smooth exterior finish and applied the vinyl glue from the INSIDE.
Once it all cured in 24 hours (72 hours for full strength) I removed the tape, cleaned off the inside a little (formed a little blob) and so far after a week, the gap stays closed and watertight.
Cosmetically, not the best solution, but then a crack / cap looks just as bad. At least it is now watertight and clear.
Last Post by smshirk
01-03-2016, 01:25 PM
Last Post by wildcat
07-15-2015, 07:42 PM
04-27-2014, 01:28 PM
Last Post by Grandpa#3
04-10-2014, 07:33 PM
10-09-2008, 09:49 AM
05-12-2008, 05:21 PM
