06-30-2015, 04:17 PM
As some of you may know or have experienced, when one motor runs and the other doesn't, you can snap the lower aluminum support (this is the support member that is vertical with a rubber seal for the window, which is bolted to the frame) on the side the motor does not operate. I bought mine with one broken and a flimsy patch.
I have gone strictly manual, removed the cables and the motors. In the process, I discovered 3 relays which are only mentioned in the schematic with no given location.
For those who plan to keep theirs original it might behoove you to check them out.
They are located on the right side near the fuel filler cap. To get to them you need to pull the carpet back that reveals the gas fumes canister, pull it further back because the relays are below the where the top's window starts. One relay switches the polarity for the other two relays, for up and down. The other two relays activate each respective motor. They are generic relays like those found in the fuse section.
The point here is that if one relay goes bad, the motor which may be good, won't actuate and then.... big problems.
