Threads: 3
I replaced those seals front and back a while ago. Got them from Sunset.
Don't recall the price, but not expensive.
'95 Black/Cashmere Cab. Airbox, K&N, STB, RSB Chip, M030 Sways
Threads: 3
Me neither !! Was thinking << $100.
Threads: 22
I have used AutoAtlanta quite a bit and have not had any problems with them. While not as cheap as Sunset, they do have the parts catalog online. Another good online source for the parts catalog is DC Auto.
-Matt
Threads: 2
I need to replace a torn trunk seal on my cab, and I am curious if anyone has used the trunk seal part that Only944.com features on their website?
https://www.only944.com/partscatalog/only/trunkseal/
Apparently it is not the exact part or profile of the original Porsche seal, but it is very similar and they say it works fine.
The point of using their seal is $90 (for their seal) vs about $250 for the Porsche part, and according to Sunset, Suncoast, Porsche Atlanta, etc., the Porsche part is 3-4 weeks away in Germany.
Tim
95 993 Coupe, Guards Red (Karl)
95 968 Cabriolet, Aventurine Green/Marble Grey (Ava)
06 Cayman S, Guards Red
(This post was last modified: 03-24-2018, 03:26 AM by
Spokayman.)
Threads: 2
Well I am going to try the aftermarket seal (that I referenced above) and see how it performs. I’ll try to provide a report back here.
Tim
Threads: 49
Please let us know, mine is rather shabby too.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 35
There must have been several people who read this and ordered the seal. I ordered one last night and got an email that they just ran out of trunk seals a few days ago. They are getting more.
Greg
'92 cab. Guards Red/Black.
Threads: 2
I ordered the seal, received it today, and installed it this afternoon.
It indeed is a slightly different profile than the OEM seal but it seems to work just fine, and in fact it makes a slightly tighter fit when the trunk is shut as one might expect with a new uncompressed seal. The difference in this aftermarket seal is mainly an extra bulge/flap on one side which serves no purpose for our 968 application.
The overall size and the way it fits onto the trunk surround metal seem to be the same as our OEM seal, or it is so close that any differences are not detectable. I have not water tested it yet though I am not expecting any problem with that.
I would recommend this seal as a useful alternative to the very expensive OEM part.
Tim
Threads: 49
Is the new seal shaped to fit the trunk area, or is it a straight piece of rubber that you just bend around the corners? If it's not shaped, does the profile change when it goes around the bends?
I ask this because I had a similar experience with "universal" door seals on my 51 Chevy truck. Where it went around the corners, it stuck out so much further than it did on the straight parts that it didn't seal properly.
If you have a chance, show us the finished product.
Thanks,
Matt
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 2
Quote:Is the new seal shaped to fit the trunk area, or is it a straight piece of rubber that you just bend around the corners? If it's not shaped, does the profile change when it goes around the bends?
Thanks,
Matt
Matt, there was no problem bending the seal around the corners of the trunk. I didnt notice that the seal deformed or stuck out in any way due to the curvature. The replacement seal was not formed but was a straight piece, and I am pretty certain that the OEM seal was also a straight unformed piece to begin with. The new seal just presses onto the metal, gripping it fairly tightly, and the bulb portion just follows the curves well. There is no buckling or bulging going on.
I wont be able to take any more photos for awhile, but I can tell you that the new seal looks the same on the car as the old one did with the little pointed tip on the top of the seal pointing straight up even where the seal goes around curves.
Tim
(This post was last modified: 04-01-2018, 06:27 PM by
Spokayman.)
Threads: 2
Quote:Great info and pics thanks!
This seal was low on my list due to cost/benefit.
My old seal has a gap at the trunk lock, presumably due to shrinking, (but water dies not seem to leak in)
Does your new seal nest into itself to complete the bead?
michael
The new seal has a tubular piece (think male) sticking out of one end that slips inside the other end of the seal (think female) where the two ends meet at the trunk latch. My original seal seemed to be bonded or glued together where the two ends met, and I’m thinking of finding some glue to do the same with this new seal. As it is, the two ends meet perfectly with maybe a 1/16” gap.
Tim
Threads: 51
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 35
Thanks for the recommendation. Seems like a good idea to glue the ends together to delay the day when the new seal will recede and show a gap.
Greg
