Threads: 69
Hello all,
How do I tell what size is on the car; 36mm or 40mm? I bought parts at the dealer for an upcoming brake job but received two different types of vibration dampers. I'm guessing the bags just got mixed up in their parts bins as they are definitely different part numbers - says so right on bag. Needless to say, I can return them but would like to make sure I get the right part #'s prior to leaving this time. PET says 964.351.096.01 for 36mm and 964.351.096.02 for 40mm. Are the fronts and rears the same? As far as I know, the car is all stock, but I can't find any reference in PET to different sizes used for different years or anything. Thanks!
Threads: 8
Caliper Pistons:
Front Standard 40mm/36mm
Rear All 30mm/28mm
Front M030 44mm/36mm
To get the pistons out, compressed air is your new friend. I hooked up the compressor (little Sears tire inflater) to the bleed screw. You must cap the opening where the brake line comes into the caliper.
Now, slowly and carefully, with no fingers in the way, wearing eye protection, etc. You add a little pressure. They will shoot out of the bores like rockets if you let them.
I followed the advice of another and "shimmed" the space between the cylinders so that all 4 pistons would extend evenly and just to the point wear I could remove them the rest of the way by hand (just before they pass the seal ring in the bore).
It worked pretty well. I installed new spring plates (if you ever want to get pads in/out easily, you'll need to do this) and popped those donated M030 calipers on last week. So far, so good.
I also did the stainless steel brake lines (track car) and changed a few other things.
The little screws that hold the spring plates in are EVIL. You will be very proud of your mechanical ability if you can get them out. Ask me how I know...
HWFM Chief Marriage Counselor
Threads: 5
Dave, were you able to install M030 calipers without installing other M030 parts?
Threads: 8
Bruce,
Yes sir! You'll need adapters (I used the ones from Racers Edge via Paragon Products), it's a direct bolt on. Corresponding rotors and pads... and you're off to the races.
If the weather holds, I'll be at the track this weekend and hopefully will have a chance to work them to their potential.
If you keep the splash guards, they may need to be bent just the slightest bit in a place or two in order to keep it from rubbing on the rotor.
The PET shows the splash guard as the same P/N for both standard and M030 front brakes. Thus, I left it on. I also don't mind that it may provide a "heat shield" to the front ball joint on that side. We'll see if that's wise or if I should just ditch them in exchange for a bit more air/rotor cooling.
I am hoping that the brake upgrade will keep me from having to spend the last half of a 90-minute enduro with both feet on the brake pedal coming into turn 5 at Road America :0
We'll see.
