I painted those rotor hats with a clear engine paint - they will hopefully not rust for at least some period of time. Still like that idea :-)
Here's a weird deal. I installed pads and rotors, repacked the front bearings and went to bleed the brakes. I start with the left rear and get maybe 2-3 pumps worth of fluid and then the pedal will bearly move, even with the bleeder open. Try the right rear and same thing 2-3 pumps and then nothing and a hard pedal ( hard pedal with the bleeder open). I check if the brakes are even working on the rear since for some mysterious reason I can't get fluid. The pads are not depressing on the rotors - do not work.
I check the fronts and the brakes work fine, depress. I decide to try bleeding the left front and get plenty of fluid and the operation seems normal.
During the pad change I opened the bleeders to depress the pistons since I would be flusing the whole system. Possible I got a tiny bit of air in there but I was pretty careful. Don't think that could cause this rear brake problem.
It's as if the brake fluid is not under any pressure at the rear when you depress the brake pedal. The pedal is hard.
I have driven this car maybe 60 miles since its been sitting for years and the brakes felt fine although were ready for replacement. I think the rear brakes were working before the brake job but its possible the rear brakes were inoperable and I didn't notice while driving the car briefly.
What the heck could cause the rear brakes to not get any pressure while the fronts do get pressure?
