Threads: 11
Hi
After watching Tom Charlesworth's video and listening to Pete at Hershey and their concerns about long term problems that may arise from using fuel with ethanol I wonder if I could get some advice about the best fuel to use. Up here the highest octane pump fuel is Sunoco 94 which is 94 octane but has ethanol added. The best fuel without ethanol is Shell which advertises itself as very clean and is 91 octane. Therefore my dilemma?
1. Stay with the 94 octane with ethanol?
2. Switch to the 91 octane with no ethanol but very clean.
3. Blend the two. This is not that difficult since both stations are across the street from each other.
4. Other
Any suggestions?
Thanks.
Steve
94 Coupe Black/Black, Option codes 288,331,398,425,454,490,650,
Threads: 16
If you chaps can get Shell V power. Its 98ron .....+ good stuff...Its freely available over this side of the pond..[UK]...As are a lot of other higher octane fuels....
Dave W.
95 - 968 Sport with Cup 1,s + 2,s ...
(This post was last modified: 05-23-2009, 08:11 PM by
Big Dave.)
Threads: 56
I have tried V-Power and I couldn't notice any change in power (although it might be better for the engine). You will have to optimize the software for V-Power to get the most advantage out of it. For newer cars, especially turbocharged, it can make a big difference but I guess our cars are a bit too old in the computer department.
Threads: 24
Around here I have usually used Shell but for a while I was using Kroger or Sam's gas when it was so high (I put 100 miles a day on mine). A couple of times, for just a minute, I got a check engine light. Flashed the codes ansd it was knock sensor #2 - not sure if that was gas related or not, but... Recently I have discovered that all of the Philips 66 stations around here use ethanol free gas. I've started using that and gained 2mpg and no more CEL.
Late 94 968. 6 Spd, Black/Black, 17" Cups. Lowered & Koni[color="#FFA500"][/color]'ed. <i> 217k miles and clicking away more every day</i>
Could be for sale if you are interested in a good high mileage car - PM me.
