this one is all about how fast and hard you drive - suspension setup plays in here too - a stiffer suspension changes how much weight is shifted to the outside tire - even setup geometry can make a pound or two change - there are too many things to give a "do this" pressure
you absolutely must use some form of testing (chalk, shoe polish, tire temps, wear pattern if you're observant enough, etc) to see what you are doing - where you set them is based entirely on how you are using them - if you aren't tearing up the edges of the pattern, you have too much air in them - if you are rolling them over past the tread, then you need more - it may feel weird at first, and even a bit soft, but the times, and the lessening of breakaway, will tell you that it's right
i had the 8000s too - absolutely hated them - i tossed a perfectly good set a few months after i got the car - second stiffest tire i have had yet - i played with those for a while, trying to find something that worked, and gave up - even on the street i was setting the 8000s to 34 front and 33 rear - any more than that and they were slipping all over the place - got a lot miles out of them though
stiffest has been the bridgestone S0-3 - i set the S0-3 at 31 cold rear and 30 cold front for track use, and those are 30 and 35 series - i use both a tire temp gauge and the chalk method to determine what pressure to set, and how to get the outside of the corner to wear - the faster i go, the lower the cold pressure - on the street i run 37 front and 36 rear, but that is just because of potholes and the low profile - any less and i bang rims - at that pressure though, i am not using all of the tire, and they heat up WAY too much on the track - now that i finally got the springs changed back out, and the shock and strut settings pretty much sorted out, i might be able to drop another pound
lol - on the lighter cars, we were starting off at 25 cold on a 205-50-15 Y2000
www.968forums.com
