Threads: 3
Your current MC might be bad, foot bleeding can be hard on them, or anytime the pedal goes to the floor. The piston travels past the comonly used area and grunge is forced through the seals.
You might also have air in your ABS controller.
Sometimes bleeding after holding pressure over time is helpful. Disable the brake lights and wedge the pedal down overnight (I use a couple blocks of wood and the seat.) In the AM, open one bleeder, then close it, then let the pedal up and wedge it down again. Pop another bleeder in the PM, and so on.
The theory is that the bubbles get smaller and move more easily under pressure.
Follow up with a normal bleeding procedure as some bubbles might collect in the calipers while others move up to the MC.
Another trick is to bleed at banjo bolts to find air that is trapped in funny places. Perhaps near the ABS pump. Be ready to clean up the brake fluid.
The Hammer probably can activate the ABS pump also, good for proper bleeding.
Good luck,
-Joel.
Joel Frahm
1987 928S4 Diamondblau/Blue
Threads: 3
Was there air in the brake system, or is the longer pedal travel a result of a larger caliper piston/cylinder upgrade?
I assume that you like to upgrade your brake master cylinder to make your brakes better suitable for track days. If so - have you studied the setup of the true and only race version of 968?
The 968 Turbo RS has a brake master cylinder different fron the other 968 models.
According to Porsche's part list, it uses part number 968.355.011.00. Ordinary 968, CS and Turbo S use 951.355.011.01.
I have no specification for this master cylinder, but I'll guess that it was more suitable for racing than the standard type.
As only 4 Turbo RS was build, I doubt that it will be easy, if possible, to get that part. Maybe Porsche can give some specification for the differ of that type of master cylinder compared to the standard. And maybe someone with experience from driving an original Turbo RS can tell how the pedal is there.
At
http://www.968forums.com/topic/7521-fron...s-at-rear/ I've specified the calipers used for original Turbo S and Turbo RS. The caliper piston sizes should match the master cylinder, or you will get wrong pedal travel. It's all about moving a specified volume of brake fluid.
Member #908 of Porsche Club Norway
Now: 1995 968 CS with Comfort Pack, Amarant Violet
x -92 964 C4 Cab, Indischrot
x -84 944, Alpine Weiss
