Boxster Calipers? Anyone?
Has anyone here fitted Boxster calipers to a 968? Just thinking... newer design. One piece. Readily available on flea bay or junk yards. The "S" model is red for a lot less $$ than actual big reds specific to the 968/911.
1994 968 Coupe / 6-Speed / Guards Red over Black Leather / Bilstein Escort Cup Coil Overs / MO30 Sways / Charley Arms / Adjustable Camber Plates / 17" Cup TWO Alloys / B&B Cat Back Exhaust / Airbox Mod / RS Barn Stage 1 Chip / Classic9 Rear Seat Delete / Saftey Devices Roll Cage / D&L Clubsport Door Panels / ProMax Wiper Delete / D9 Brake Ducts / Design 1 Racing Splitter
I was looking into Boxster S brakes as well, as it seems like it should be a no-brainer mod, but could not find a definitive answer.
Questions:
Will Boxster S rotors fit on 968 hubs?
If yes, then is a spacer/adapter all that's needed to fit Boxster S calipers to 968 hubs? Maybe we can get someone to make one...
If Boxster S rotors do not fit on 968 hubs, then could Boxster S calipers be used with stock or M030 968 rotors with a simple spacer/adapter?
Inquiring minds want to know!
-Austin
'94 Black/Tan Coupe
I'm going to look into this weekend. A buddy of mine has a set of Boxster calipers. I will do some measuring.
Flash, any insight on this topic?
-Austin
'94 Black/Tan Coupe
After looking at the available options, I've become fairly serious about having a custom kit built from Stoptech components, as I think these represent the best value for dollar. The M030 and Big Red/Black options that are widely available give plenty of heat sink capacity for the track. I want something that also improves pedal feel, and from research, personal experience, and anecdotal discussions I don't think that's possible without (1) newer caliper technology at all 4 corners and (2) floating rotors. I'd also like to retain the OEM brake bias, which is thrown off dramatically by simply bolting on larger front calipers. The car is perfect with non-M030 front calipers and the 5/33 brake bias valve.
Interesting, please keep us updated!
i have no info on boxster stuff - sorry
the reasoning cited above is exactly why the only brake mod i am likely to do is custom made larger floating rotors, but still using the OEM calipers - i just haven't gotten to it yet, as i don't need rotors just yet - i do know that i will NOT be making any of these for anybody else - the liability is just too high
09-03-2011, 07:03 PM
