11-08-2005, 09:07 PM
My car, rather than riding near the 8-9o'clock mark on the temp gauge, is instead near the 10o'clock mark. I've bled the system over and over but only got air out the first 2(two) times. I've had the radiator out before, and never had a problem bleeding it, and so don't suspect any air pockets in the system. All variables are the same (as pre belts, variocam, seals, rollers, tensioner, hoses) with the exception of the impeller design of the waterpump and the thermostat. The thermostat rather than an aftermarket low temp unit, is a Porsche regular temp unit. I have a low temp fan switch installed. The impeller differences are in the pics below.
So this is the impeller on the new water pump:
![[Image: New%20Pump%20Prop.JPG]](http://flyservers.registerfly.com/members5/2rtr.com/images/New%20Pump%20Prop.JPG)
This is a pic of the impeller in the old waterpump:
![[Image: Old%20Pump%20Prop.JPG]](http://flyservers.registerfly.com/members5/2rtr.com/images/Old%20Pump%20Prop.JPG)
My old waterpump was also a rebuilt from who knows where. Zims Autotechnik (whom I purchased the new unit from) says that they use the same (rebuilt) impellers as Porsche. They checked a unit in the back, and it's the same as the new one I have installed and is supposedly the same unit. Sunset (Jeff and Phil) seem to recall the aluminum round solid version to be "newer" as that is what they recall most recently handling. Does anyone recognize one impeller to be a newer/better design than the other? Who has the aluminum disc (round solid) version in their car with no problems? Does anyone have advice for figuring out why my car is running hotter?
Rustech
