Threads: 45
From Porsche they are a small fortune
Called a Governor in PET
928.603.142.01 $212
Threads: 49
Quote:Sadly, our last old school auto electric place closed last year. Luckily, I had them rebuild my Beck starter and alternator before they did. So its reman or new for me.
BTW, is anyone currently driving their car? Whats your ammeter read. Ive had zero issues with the new battery, and Ive put enough miles on it that if the alternator wasnt charging, it would have manifested.
When you get to the dash lights and the light tunnels (on the list of items to check for new owners) clean the contacts on the screw posts on the instrument cluster. I found that my gauges all improved, the fuel gauge went closer to full and oil pressure improved along with voltage.
Look for the new owner link, there is a laundry list of things that are known issues for these cars.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 45
just replace the voltage regulator, then spend a happy few hours cleaning all the grounds, the football shaped connectors on the back of the cluster, I promise it will keep you out of trouble for most of a day
Threads: 45
Just remember to disconnect the battery before starting
You need a 1/4 drive socket set, and some nimble fingers and your good to go
Threads: 49
I swapped out my original (118kmi) regulator yesterday for a Hella unit I picked up on eBay.
The job was a bit of a pain, but a trick I tried was to tie the brushes in with a thin piece of string, get the regulator in and the screws tightened a few turns, then cut the string to release the brushes and pull it out with needle nose pliers. It took 3 tries to get the string set to the proper tension, but as my friends say on the other side of the pond, it worked a treat.
The brushes were worn down to nubs, so the timing was right. But the strange thing is, the voltage at the gauge has actually dropped. It runs between 12 and 13 after it charges back the loss from starting. I expected more, but it seems to start and run fine, so I am going to go with it and clean the grounds this week.
Anyone want to remind me where the body grounds are located?
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 45
They are
Chassis rails by headlights inside
Rear of engine to firewall
In both footwells look straight up
Trunk battery cable, and one on the left hand side under the carpet
Roughly!!!
And it should only trickle charge at anywhere between 12.8 and 14.4 when the battery is full
(This post was last modified: 06-06-2023, 01:15 PM by
Waylander.)
Threads: 45
12.6 is a fully charged battery at rest, anything above that is a charging voltage
The other thing of course is just how accurate is a 30 year old volt meter,
I would expect to see at least 13-14.4 as the charge rate, my regulator expired and I have fitted 3 since, all have been higher voltage than the old one, as long as its not over 14.8 as a max your ok
Any more and you will boil the battery, not a good idea
Threads: 45
Time to replace the DME relay, for a known good one or new
Threads: 17
volvo V70D5 Black
Porsche 968 amethyst
