Threads: 42
When car is started, volt gauge on dash doesn't move until I give a little gas. I measured battery voltage and before i give it gas, shows 12 volts, so would seem alternator is not sending current to the battery at that point. After i give it gas and the gauge moves up, battery shows 13.6, which suggests alternator is then working. Any thoughts on why giving gas starts the voltage flowing? Is this a battery cable issue? Alternator is relatively new as is battery. Thx
2005 Acura RL
2004 Toyota Sequoia
Threads: 77
Is the exciter wire securely fastened to the alternator?
Threads: 42
Yes, alternator connections are tight. I didn't think it would be a gauge issue because it seems to be reading what the alternator is putting out, which is nothing until I jolt it as you say.
2005 Acura RL
2004 Toyota Sequoia
Threads: 77
Maybe have battery checked? Possible you have a bad cell in the battery.
Threads: 42
It doesn't vary other than as described. Once it senses voltage and registers on the gauge, it acts normal and stays steady.
It is not the battery.
2005 Acura RL
2004 Toyota Sequoia
Threads: 42
Yep, starter and battery connections are tight, all other gauges work. Starter and alternator were both replaced over a year ago., Car starts and runs normal, just doesn't seem to initially get power from alternator. Is there a relay that may be suspect?
2005 Acura RL
2004 Toyota Sequoia
Threads: 42
So maybe alternator is issue? If that is case, I'm inclined to leave it, pretty minor thing.
2005 Acura RL
2004 Toyota Sequoia
(This post was last modified: 07-18-2013, 08:21 PM by
rl968.)
