Advance posting of intended drive
I plan to bring my white car to Newtown for September 13 and 14 to have Pete replace the DME wiring harness, replace all the engine sensors and do the major service to the belts, etc. I leaving home on Saturday, Sept 11 and will be arriving there sometime on Sunday. I do not know where any of you live but I seem to recall that there are numerous members in the "general" area. I don't want to go exceptionally far out of my way for fear of getting too lost but if anyone is on the general route I am always up for a rendezvous.
Kim Strong, Nova Scotia
2022 Mustang Mach-E
How long will you be staying? I definately want a chance to have drinks and dinner with you while you're in town. You have my # and my e-mail...
Regards,
I may be out that way as well. Been wanting to get back and do some more exploring of the area. May be on my bike though......
Rico Suave
Plan is to be in Newtown on Sunday and Monday nights, leave on Tuesday to go back as soon as Pete is done the work. So Jay either of those two nights works for me.
2022 Mustang Mach-E
Just a reminder that this is still on. I am coming straight down from Ontario on I-something-or-other through Scranton(?) and will be by there on Sunday afternoon. Otherwise just heading straight to the Brick hotel in Newtown.
2022 Mustang Mach-E
Planning on a very casual dinner on Monday night the 13th if anyone is going to be in the neighborhood, give us a shout.
Ok so I have this all set now. No stops other than Newtown. May have some <i>en route</i> rants to post later.
2022 Mustang Mach-E
Here I am. In Newtown. Just made it - the variocam switch was cutting in and out and the hall sender codes were sending me down the hall. Good times tomorrow. Or else I can't get home.
2022 Mustang Mach-E
First day over. Let's see - new rad. New waterpump. New sensors, new variocam chain and pads, new (to me) intake plenum, valve cover and vanity cover, new DME harness, and tomorrow isn't even here yet!! Wahoo!
2022 Mustang Mach-E
There really needs to be a legislated upper limit to the amount of fun one man can have on vacation.
2022 Mustang Mach-E
I wonder if I would call spending money on maintenance as "fun".
Ah... I get it! It just means that you will have less headaches / worries when your driving around!
OK... have LOTS of fun! [img]style_emoticons/<#EMO_DIR#>/wink.gif[/img]
sadly, it would not start after the test drive. so I have to leave it here and fly home. will come back to get it later once whatever is wrong is made right.
2022 Mustang Mach-E
Another opportunity to hang out and dine in Newtown...
Well well well. So the head on my car died IMMEDIATELY following the test drive after installation of the new wiring harness, water pump, radiator, engine sensors, variocam chain and pads, cam belt, balance shaft belt, and miscellaneous new wires and do-dads. Absolutely amazing timing for this because had it died one start later I would have been 400 km away from Newtown and been rather unhappy at my predicament. It is not repairable. I had to take a plane home and will need to come back in a bit to get it. So Pete and Max are looking for another. Yes, that veiled post by Pete is for me. May just now elect to do the rings also and have a new car.
Anybody need an 08 Cayman S with 40K kilometers?
2022 Mustang Mach-E
it always amazes me how things connect - it also amazes me at how these engines run with so much wrong - apparently the timing was so far off that it ran, even though thins were wonky, but as soon as things were timed correctly, it no longer ran
bummer to find it out like that, but the good news is that it will feel so much better when it is running right
i'd go the whole way, given how much mileage is on it, and then enjoy it for a very long time - otherwise, you'll be back in there before too long, and again wondering why you kept the car
On a happy note, I can't imagine a place on Earth I'd rather my 968 die. Reminds me of the time that Mark's waterpump blew, 200 feet UPHILL from RSB.
She'll be good as new and you'll be back in love again soon.
Regards,
Pete has already been advised to do the entire engine.
2022 Mustang Mach-E
Final report. What's new:
Head gasket
flywheel
engine mounts
main bearings
rod bearings
piston rings
new head
Oil pickup tube
DME wiring harness
all new engine sensors
rear hatch removed and resealed
oil pump
all belts, seals, etc.
oil pan gasket
Love and care added at no additional cost.
And some funky black lettering on the vanity cover.
Drives like new, probably mostly is new.
was fun and, like Arnold, Ah'll be bach.
2022 Mustang Mach-E
Last Post by Velocity
08-23-2022, 10:45 PM
06-16-2022, 09:04 PM
04-09-2021, 07:05 AM
04-10-2015, 06:57 AM
05-16-2013, 01:44 AM
