968-996 headlight mod
Looks like we need this one for an all in one unit (if a little pricey..)
Jake
[Image: Bi_Xenon.jpg]
90mm Bi-Xenon HID Low/High Beam Lamps
The Bi-Xenon provides both high and Low beams in an HID Xenon lamp. This is accomplished by a shield which creates a Low Beam cutoff and retracts for High beam.
Each lamp includes the D2S Capsule, Ballast, adjuster screws and connector cable. The wiring harness, is not included.
Specifications
Lens Diameter 3.54" Lens Face to Mounting Plate 3.69"
Width At Mounting Plate 4.88" HID Capsule D2S
Height at Mounting Plate 4.68" Ballast Cable Length 44"
Overall Length 7.75" Voltage
12V
Bi-Xenon Lamps
Item # Description Price Quantity Add to Order
HL68141 90mm HID Bi-Xenon Lamp, D2S Capsule, Ballast, Adjusters, each $538.46
Accessories
HL68141SC Connector, Shutter Control for Bi-Xenon Ballast, w/ Pigtail. One Required for each lamp. $4.11
HL78400 D2S HID Capsule, each $101.00
HL87700 Ballast, each $190.77
HL87229 Connector, Power for Bi-Xenon Ballast, w/ Pigtail. One Required for each lamp. $8.50
If someone can come up with the appropriate mounting hardware and body counter clear cover, I'm ready to do this. Great find, Jake.
and the old fender is now in my garage - i don't want to cut it, or harm it, but it is available for a while to use to see if a conversion can be done - then i am selling it because the dent is VERY repairable - i just didn't want any bondo on my car
[quote name='Anchorman' date='Mar 24 2005, 08:19 AM']IMHO [the pop-up headlights] make the car go from elegant, clean lines to Kermit.
[right][post="2261"]<{POST_SNAPBACK}>[/post][/right][/quote]
Anchorman that is so hilariously accurate !
This mod is a real tempter. Another benefit might be worth while weight reduction for us diet junkies. Does anyone know how much Kermits eyes weigh, including lift mechanisms?
sparky
Porsche #1: MY03 Boxster S (sold)
Porsche #2: MY94 968CS red (sold)
Porsche #3: MY94 968CS M030 white (fast!)
non-Porsche #1: MY91 Acura NSX (not bad for a non-Porsche)
[quote name='sparky' date='Apr 8 2005, 06:06 PM']Anchorman that is so hilariously accurate !
[right][post="3043"]<{POST_SNAPBACK}>[/post][/right][/quote]
<img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
This whole Kermit bit brought a big smile to my face.
about 30 lbs - and on the very front of the car
c'mon - you knew i'd already been there - lol
[quote name='flash' date='Apr 8 2005, 04:02 PM']and the old fender is now in my garage - i don't want to cut it, or harm it, but it is available for a while to use to see if a conversion can be done
[right][post="3042"]<{POST_SNAPBACK}>[/post][/right][/quote]
At least we should take a splash of the opening and surrounding fender area.
sure - whatever - if it wasn't so easy to bang it out, i'd feel differently - somebody that doesn't want to spend the money on a new one, and has a badly dented one, will walk away happy here for very little, if they are wiling to spend about 2 hrs on it
Below is a picture of the strosek cateyes which Van Zweeden sell.
I know they look horrible, but wonder if we could coat them in silver, put the litronics unit in them then put a clear lense over the top - if nothing else it might work as a proto-type? They fit the standard 968 opening with no modification. They also sell the lights to fit these but i don't know what the spec is.
Jake
[Image: bodypics281.jpg]
[Image: bodypics505.jpg]
When it comes to fixed headlights, it seems like this outfit (Ark Tech) already has something. See link below (hope it works; haven't tried this on this site before <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
My Webpage
As you can see (if it went through), this mod uses 993 headlights. I you ignore the hideous spoiler and the strange color, these fenders and headlights are drop-dead gorgeous. I can't imagine a more perfect headlight mod for the 968. I don't know anything about Ark Tech (a google search turned up nothing), or if they are even still in business, but they're proven a 993 fixed headlight conversion can be done, so, with all due respect to those who have tried, why even mess around with non-Porsche headlights? There's probably enough interest in this mod that I would think that somebody like RS Barn, Powerworks, or Van Zweden could be persuaded to duplicate what Ark Tech has done.
Well, the picture of the Ark Tech fender/993 headlight mod did make it, but you have to scroll down to the sixth response to the thread. In the discussion, some people mentioned that the price of the Ark Tech fender mod was very high, but I didn't see any reference to it.
The Arktech web site has been down for a long time. My guess is they are out of the business.....
http://www.arktech-motorsports.com/
They are still in business as they are running the 968 GT4 and a 996 GTR in the Super GT championship. I was watching it the other day and the 968 caught fire in the pits <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" /> and the GT3 crashed
[Image: 04tm111m.jpg]
Arktech team info
- i emailed they last year re the cost of the mod but got no response
Jake
And here it is before it caught fire!
Jake
[Image: 0501_020.jpg]
06-24-2020, 11:45 AM
Last Post by gbarrier
04-24-2013, 11:13 PM
Last Post by DaveN
06-12-2011, 02:04 PM
Last Post by Gotter
07-10-2010, 12:51 AM
Last Post by smj
05-13-2009, 08:43 PM
04-14-2005, 01:17 PM
