04-26-2011, 07:46 AM
Given I now have the car back in my hot hands (and have taken it from one side of Australia to the other - on the back of a trailer), it is time for an update.
As those of you who have seen my other posts, I have gone down the path of forced induction. Given that the car is mostly used on the track, I was looking for more horsepower. Flash did not have any more kits in the pipeline, so given my timeframes (car was to be ready for the first round of competition in January 2011), I ordered the 928 Motorsports kit.
I ordered the kit in December 2010 with a delivery date of very early in January 2011. The kit did not make it, being shipped on the 25th of January 2011. I will cut to the chase, the car was at the mechanic's on the 10th of January (I was also having the engine rebuilt) and I picked it up (almost complete) on the 19th April 2011. The installation is not yet complete due to several issues which I will discuss below.
There are numerous issues that I have had with this kit. I am not sure if some of these are due to the engine being brand new (higher compression), but the majority are due to the kit's design. I went into the process with my eyes open, but even so, I did not expect the amount of grief I have had to work through.
When I looked at the dyno graphs on the 928 Motorsport's website, the power drop off over 5,500rpm was a concern. I was not sure if this was due to exhaust backpressure, belt slip, injector fuel delivery, etc. To make sure that we did not grenade a brand new engine, we always intended to run an aftermarket ECU to ensure that the car was custom tuned.
Issues found;
1. Driving the supercharger of the back of the belt does not work - the belt slips from idle and the knurling on the pulley creates severe wear. Solution - machined the supercharger pulley to accept a double ribbed belt (i.e. ribs on both sides of the belt). The kit comes with a 6-vee belt, but currently running a 5-vee belt. Will have to do some more work as pr below on pulley sizes, etc and get a 6-rib belt.
2. Injectors lean out at high rpm - at high rpm and WOT - the injectors are at 100% of capacity. The supplied 45lb injectors were replaced with 60lb injectors (note that the rising rate fuel regulator was also removed and the fuel delivery controlled by the ECU through pulse duration only).
3. Radiator and A/C condensor had to be dropped around 20mm to fit.
4. Supplied fan with kit does not work. Re-installed original twin fans.
By using an aftermarket ECU, there is no need to run the MAF sensor. This has been removed.
We have a custom made intercooler mounted in the front of the engine bay.
Here is what the kit should look like according to the 928 Motorsports Website (not sure if I am allowed to post this - but it is an image taken from their website);
Here is what our installation looks like (this is prior to the bonnet/hood being re-installed);
Issues found;
