03-02-2008, 03:47 PM
I've been trying to figure out tires and have been struggling a bit with getting a sense of when you cross over from "that's cool and should work for that wheel" to "you're an idiot, if you use that tire on that wheel your car will blow up".
This has just gotten a bit more serious for me as I find myself with some new 18" wheels / tires and am worried about the rear tires - more on that later. So...am just thinking that this thread could help tell us for those who have 18" wheel what tire size is working for them. Here are a couple of helpful links I have found here:
968 Engineering Wheel Calculator
DML Tire and Wheel Calculator
Note that below the calculator shows the difference in millimeters from OEM 16". The front to rear OEM difference is (0.09%).
First off this is Anchorman's setup, and from what I can see seems to work great, and looks great too (pic below on right):
F: 8x18 / 57 offset, R: 10x18 / 58 offset.
Tires: Goodyear Eagle F1 GS-D3
F: 235/40ZR18
R: 265/35ZR18
Calculator (from 16" OEM):
F Diameter: 13.3
F Inboard Clearance: 17
F Outboard Clearance: 13
R Diameter: 11.3
R Inboard Clearance: 26
R Outboard Clearance: 14
Front to Rear Differance: (0.39%)
Here is what I am looking at (pic below on left) - am worried about the rear tires...should I be? What will the 3.6% difference do to me?
Tires: Continental SportContact 2
F: 235/40ZR18
R: 265/40ZR18
F Diameter: 13.3
R Diameter: 37.8
Front to Rear Differance: 3.59%
Brian's setup:
F: 7.5x18 / 50 offset, R: 10x18 / 65 offset.
Tires: Dunlop FM-901
F: 225/40ZR18
R: 265/35ZR18
F Diameter: 5.3
F Inboard Clearance: 5
F Outboard Clearance: 15
R Diameter: 11.3
R Inboard Clearance: 33
R Outboard Clearance: 7
Front to Rear Differance: 0.86%
F: 235/40ZR18
R: 265/35ZR18
F Diameter: 13.3
R Diameter: 11.3
F: 235/40ZR18
R: 265/40ZR18
F Diameter: 13.3
R Diameter: 37.8
Brian's setup:
F: 225/40ZR18
R: 265/35ZR18
F Diameter: 5.3
R Diameter: 11.3
(This post was last modified: 03-02-2008, 09:26 PM by Simuse.)
