Threads: 48
Hey Flash,
Is this brace compatible with the rear engine cover, and do I still need the strut brace in order to install this?
Thanks,
Johann
Johann van Biljon
'60 Aetna Blue 356B T5 Coupe
'79 Silver 924 5 speed - Sold
Threads: 10
I'd like to install the firewall brace, but do not wish to install the strut tower brace. However, the firewall brace requires the driver's side strut tower bracket.
Would there be any interest in selling the driver's side strut tower bracket as a separate item? Thanks.
Joe
Joe
1995 968 Coupe
Guards Red/Black
Threads: 77
Has the clutch pressure plate ever been replaced in it? You could have the heavier pressure plate that is sold these days.
Threads: 15
Flash's firewall brace will also work with the KLA strut tower brace - you just have to shim where the brace attaches to the strut bar upright with a few washers and get a longer bolt.
I know Flash doesn't recommend using the firewall brace with the KLA unit, because the KLA upright does not have the extra triangulated brace that the D1R upright has, so do so at your own risk, etc.
Seems to be working fine on my car, however, my firewall still flexes - a PO installed a monstrously heavy HD clutch - but I feel a tiny bit better knowing the brace is helping a little.
-Austin
-Austin
'94 Black/Tan Coupe
Threads: 22
I have a KLA brace and I made a bracket that attaches to the upright and then to the shock tower. There is an existing hole in the shock tower which needed to be slightly enlarged and then everything bolted together. Seems to work without any consequences. What do you think?
Carl
1992, Guards Red, Coupe, 6 spd., LSD, Drilled frt. rotors,
Threads: 51
LS...that is a work of art my friend. Very nice.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
