Threads: 35
I find the arms/blades obstruct my view also. My wifes Murano has side mounted blades, which allow the arms to be very low -- pretty much behind the blade. Is there something special about the mounting point of the 968 arms that would not allow you to use arms from another model of car that had better arm/blade geometry?
Greg
'92 cab. Guards Red/Black.
Threads: 35
In your bottom picture of post #29, look at the passenger side wiper. The first segment of the arm (from the mounting point over to the pin/joint where it connects to the second segment) goes up at something like a 30 degree angle, a couple inches height from the plane of the windshield. Then the second segment goes pretty much parallel at that height over to the connection point with the blade assembly. That puts the whole arm in prominent view when looking forward from the passenger compartment. Why wouldn't it be possible to use a side-mount blade where the arm was down much lower behind the blade and out of view? I'm 6'3 and the wiper arms still get in my line of sight.
Greg
Threads: 35
Yes, it's my hood. I didn't say I can't see to drive. I'd just rather not have the arms so prominently in my view. Sometimes you are looking down your hood also - not always at the horizon.
The arms/wipers are an ugly interuption over an otherwise sleek/rounded hood (assuming the headlights aren't up). Seems like there should be a better (lower/sleeker) alternative out there. I'll look when I go home to see where they rest, but I don't think it matters much because they are so high from the body of the car.
Greg
Threads: 15
Flash this is just one of those things that either bugs you or it doesn't, and our 968 wiper arms seem get my particular brand of OCD in a twist. While the wiper arms are in no way blocking my view of the road, they just sit too far off the windshield and look kinda clunky and dumb. My wiper arms are currently off the car and the look without them is super clean - really smooths out the look of the car to get rid of that visual interruption.
My mechanic owns a 951, and I've noticed that the wiper arms on that car are much tighter to the windshield. I'm wondering if 944 wiper arms will work on a 968. They should unless the pivot point locations have changed. I can't imagine why they would have - but then why the change in the arm design?
-Austin
'94 Black/Tan Coupe
Threads: 15
I think you're right, Flash. I figured that might be the reason for the design change - a better angle for the spring that holds the wiper down. Which brings up the point though that in this country we're typically not driving 120 mph on a rainy autobahn. I think I might look into 944 arms.
-Austin
'94 Black/Tan Coupe
Threads: 35
I don't drive in the rain unless the weatherguessers are wrong. If I find something that fits and looks better, I'll post. Not at the top of the 968 to-do list though.
Greg
