Threads: 15
Hi guys - I'm just about to tackle the job of putting on a set of M030 sway bars. I have these end links (below) on hand - they are 3" center to center minimum. Will they work on the rear? I haven't taken a look under the car to see how much room there is. Thanks for any input!
-Austin
'94 Black/Tan Coupe
Threads: 15
These were originally bought for my E36, when I was - mistakenly it turns out - told that my rear swaybar links were going bad. The stock rear links on the 968 will of course work fine with the 19mm bar, but if these adjustable links fit I'll be able to dial out any preload (for zero extra money!) when the car goes in for alignment after I install my newly rebuilt front struts. Will probably be doing that install next weekend. Bob, I'll give you a call after you get back.
-Austin
'94 Black/Tan Coupe
Threads: 15
Yes I have the triangulation braces for the front and will be installing them this coming weekend, along with all new bushings for the M030 sways. Staying with rubber - for now...
-Austin
'94 Black/Tan Coupe
Threads: 15
Cloud a few places carry the braces for the front swaybar brackets. I got mine from Pelican:
http://www.pelicanparts.com/cgi-bin/smar...%2C%20Pair
You can see in the photo on the above web page how the brace triangulates the wimpy swaybar bracket, keeping it from flexing under load (well, keeping if from flexing
as much under load anyway). A definite must have for a track car or any car with M030 sways - that's pretty much all of us right?
-Austin
'94 Black/Tan Coupe
Threads: 15
Tama - yes, the braces come two to a pack.
-Austin
'94 Black/Tan Coupe
