Threads: 19
Front 8x18 ET 52 with 225/40x18
Rear 11x18 ET 40 with 295/30x18
Will these fit without any issues? I run a standard setup. These would be rather wide and slow down the car considerably, but I don't think they would ever lose grip <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" /> They are actually the 996 Turbo Twist II's so if anyone has fit those on their cars without any problems let me know <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
94 White 968. Chip, M030 sway bars, intake mod & more on the way!
Threads: 19
Hmm... Thats to bad <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" /> My wheel search continues...
Threads: 19
Thanks <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> Thats helps when looking at the ET for the wheels. Atleast to give me an estimate of whether or not they will fit.
Threads: 18
I was looking at new weels and they are 8.5 , 48 offset front and 9.5, 50 offset rear
would this be a good combo?
93 midnight blue cab
03 kawasaki zx6rr
03 k2500 duramax
83 944
66 volkswagon squareback
Threads: 18
[quote name='rustech' post='40039' date='Aug 16 2007, 08:06 PM']The rear would be perfect with a 275 tire if you run ~1.5 deg neg camb even if you are lowered. It's the same I'm running.
The front would be close but you should be ok. I wouldn't go thinner than a 235 on that 8.5 rim. If you have a stock ride height, you would probably be ok. If you are lowered, you would prob. have to run 1.2 deg neg camb or more.[/quote]
Thanks I was worried more about the front. Where would itbe close the fender or struts, I have new stuff
up front so I don't think that would be a problem.
03 kawasaki zx6rr
03 k2500 duramax
83 944
