Threads: 20
What is the proper recommended torque for lug nuts on the 968? How often do I need to check? Any help would be greatly appreciated.
Jeff Mangum
[[/b][/color][/font]'92 Polar Silver Metallic Coupe (Tip)
Threads: 20
Jeff Mangum
Threads: 137
95ft/lbs and I check mine about once a month. There's always at least two lug nuts that are less than 95.
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
Threads: 137
Anchorman - I'd rather be technically correct any day! Press on...
So then what technically should we call it when we 'torque' a bolt to a specifice setting?
Michael Sorbera
2002 VW Beetle TDI
Threads: 73
Anchorman's information doesn't "torque" me. I like it. I have three torque wrenches....aka tork in some venues.
For smaller bolts, I use a small, sensitive, dial indicator torquiing device. For lug nuts, WalMart might work. I save my Snap-on for more critical, less frequent work as I don't want to wear it out.
Harvey
"There's one in every crowd"
Threads: 5
Sears should have several torque wrenches that measure in inch pounds. For example this one would work fine set to 60 inch pounds
http://www.sears.com/sr/javasr/product.do?...pid=00944593000
If not Autozone or other car parts stores should have something similar on the shelf for $20. I used some cheap torque wrenches until they failed then bought three craftsman torque wrenches.
Threads: 8
The steel lug nuts allow a visual confirmation of sufficient thread engagement, which is pretty important as well.
The alloy nuts do not seem to like being taken on/off 20+ times a year. Bloody things get pretty brittle.
HWFM Chief Marriage Counselor
Threads: 73
[quote name='Cloud9...68' date='Jan 6 2006, 09:16 AM']Harvey,
At the risk of yet again going somewhat off topic, I'm planning to do the sunroof motor torque check procedure described in the DIY section (it's averaged in the mid-seventies all "winter" here in Austin), and the procedure calls for a very small torque wrench, one that can accurately read 5 ft-lb. What type of wrench do you have per your description above that you use for smaller bolts? My local Sears didn't have one that went low enough. Thanks.
[right][post="14263"]<{POST_SNAPBACK}>[/post][/right][/quote]
The small torque wrench I have I got off Ebay and it goes from 0-50 ft lbs or 0-70 Newton Meters. It's marked:
CDI (made in USA)
#5120
OC 242
12/91 (so it is pretty old, I hadn't noticed)
Harvey
