Black steel lug nuts?
Does such a thing exist? I'm wanting them for some 993 Cup rims I picked up recently that I'm having powder coated black. I looked around, and the only black one's I find are aluminum. I thought about painting or powder coating the lugs but it seems they would get nicked and have the color come off after a few cycles with a tire iron. Thoughts?
1994 968 Coupe - Grand Prix White/Marine Blue - 6 sp - D1R Supercharged
How about Parkerizing? Can you get nuts that are not chromed?
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
[quote name='MCL968' timestamp='1406742012' post='160675']
How about Parkerizing? [/quote]
Interesting, let me look into that...
Pretty easy to do at home with a parkerizing kit, but I have always sent parts out to get done. In my experience, the darkness of the finish depends on the amount of carbon in the steel.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
My aluminum lug nuts were probably original to the car and were making me nervous. I found a set of black steel lug nuts on eBay a couple years ago. No problems. Take a look, there's probably some available there.
-Austin
'94 Black/Tan Coupe
Paragon has black steel lug nuts (at least they show them on their website).
Greg
'92 cab. Guards Red/Black.
[quote name='BeBe' timestamp='1406753839' post='160685']
Thanks to Bebe, I ordered a set of the black(ish) steel lug nuts. I'm impressed that a set of 20 - with 2 day shipping - was only $41.65! That's the cheapest I could find them, in any color, and if they look as black as the picture, they should work just fine!
the ones i saw at paragon are through hole. you can see the stud. fugly.
[quote name='flash' timestamp='1406781671' post='160707']
I thought that's what the Track techs wanted, in order to be sure your wheels are on securely?
I picked these up for street use. <img src="/forum/images/smilies/968/clap.gif" class="smilie" alt="" />
I seem to remember with my1979 924 it came with aluminum lug nuts for the alloy wheels, but a separate set of steel nuts for the spare.
[quote name='flash' timestamp='1406781671' post='160707']the ones i saw at paragon are through hole. you can see the stud. fugly.[/quote]
Different strokes ... Although admittedly , at first when I realized that's what comes with the longer studs on the spacers I also thought they might look weird, but right after putting them on the car I immediately thought and still do that the through-hole ones look 1000% better than the capped lug nuts. Mine are not black, they're grey-ish, same as the steel studs , so they sort of blend in with the rest of the wheel .. I'm also getting those for the tip now that I'm putting spacers on that car as well .
Mine are so deeply recessed in the rim that I did not remember if they were black or chrome. They are black, but you can't really notice through-hole or not unless you use a flashlight.
Greg
Last Post by 94SilverCab
05-02-2018, 10:15 AM
Last Post by hot968
07-27-2008, 10:08 PM
Last Post by cosimo
06-19-2006, 04:08 PM
Last Post by Harvey
01-07-2006, 06:56 PM
