Wheel Alignment specs for track
Hi all,
I wonder if some of you regular track guys would like to share your alignment specs for circuit work? I run my 968CS at track days etc. and am looking for a baseline alignment. I run DOT legal R tyres ( Toyo R888's or Bridgestone RE55's ). I'm not too concerned about tyre wear on the street.
Thanks in advance!
Craig H
Craig, I got my best times on the track with 3 degrees of negative camber in the front and two degrees of negative camber in the rear. Just a bit of toe-out in the front and none in the rear. I was running the 18 inch wheels with Hoosier A6S06 tires. Good luck, Bob Blackwell.
well, whether or not you have a strut tower brace dramatically affects the amount of camber you can run up front
so does ride height
so does spring rate
so does the track - what you would set for an autocross would not be anything like what you would set for a road course
can you fill us in a bit more on what your setup is (beyond the presumed M030 struts, springs, etc) and what you are doing with it (road race, autocross, etc)?
A general range for a race spec would be:
front:
-1.5 to -3.5 camber
max caster
-.10 total toe out to .10 total toe in
rear:
-1 to -2.5 camber
0 to .12 total toe in
Where you go in that range depends on specifics of the car, track, tire, personal preference and testing.
I usually end up around -3+ camber front, .10 front toe in, -2.5 rear with a smidge of toe in.
YMMV.
Thanks guys for your help, that's the ballpark numbers I was looking for. Much appreciated.
To answer other questions just FYI, it's used for circuit racing, M030 suspension ( Koni's and rear sway set stiff ), about an inch lower than stock 968CS height ( low ).
Craig H.
Last Post by bill3
08-12-2014, 11:12 PM
Last Post by Dubai944
09-07-2013, 09:41 AM
Last Post by cosimo
05-10-2012, 04:47 PM
