11-19-2024, 09:47 PM
I have a 92 968 that is stripped down to 2860 lbs. It is a mostly track car, since it has sticky 10" tires and no A/C, no radio, etc. This is my first Porsche, but I am a very good mech, and I do all my own work on my cars, I know how to do front wheel alignment, but this is the first car I've owned that requires 4-wheel alignment, so I need some help. i have read the service manual and understand how to do the rear wheel toe & camber adjustments.
Car has a square wheel setup with 17" x 10.5" wheels, MOTON Clubsport coilovers with 550# front springs, 800# rear springs. Car has manual steering and is lowered as much as practical. Roll Centers were measured to be 45mm Front, 120mm Rear (obviously above the ground). I've read everything I could find on preferred specs for this car (OEM, street, auto-X, track).
When I took delivery, car was currently set up as follows, and does not handle very well - it's OK, but I expect a lot better from a Porsche 944/968. Car is twitchy, even at street speeds (left is driver side):
Caster - as much as you can get (have not measured it)
Camber Front -2.5 deg on right, -4 deg on left
Camber Rear -4 deg right, -5 deg left.
Toe - 4/16" Toe OUT on Front, 5/32" Toe IN on Rear (total)
I changed ti to be this, and now it handles worse:
Camber Rear -2 deg
Toe - 1/6" Toe IN Front, 1/8" Toe IN Rear.(total)
Height - even front to rear
Everything I've read says a little Front Toe IN helps the car to be more stable at high speed, but most other cars I've driven feel more stable to me with a bit of Toe OUT in front. Also, a little Rear Toe IN should help the car be more stable, but this car already has Toe IN and still doesn't like to go in a straight line - needs constant correction.
Is what I just said about Toe IN correct?
I want it to drive more stable and straight at high speed, I don't care if it has a little understeer. I can tune that out with shocks and swaybars and tire pressure.
Ideas? Comments?
Thanks,
- George -
Camber Rear -2 deg
Ideas? Comments?
Thanks,
- George -
