On the back of the WaterWetter bottle they claim:
50% glycol + 50% water - 228 degrees
50/50 + WaterWetter - 220 degrees
Water only - 220 degrees
Water & WaterWetter -
202 degrees
Ok, I didn't fall off the turnip wagon yesterday so I know marketing drivel is just that, drivel. Is this just marketing hype or are these figures representative of the decrease I'll get in temperature?
Fan switch/thermostat issue - I have a stock fan switch and thermostat in the car now with 50/50 mixture (non-phosphate).
I have in my hands:
1. 75 degree fan switch - Wahler PN# 251 959 481 75
2. 71 degree thermostat - Wahler PN# 056 121 113 71
3. 85 degree fan switch - Wahler PN# 251 959 481 K
4. 80 degree thermostat - Wahler PN# 056 121 113 A
Remember I live here in South Texas = HOT, MUGGY and did I say HOT? <img src="/forum/images/smilies/968/rolleyes.gif" class="smilie" alt="" /> And I drive the car everyday, in traffic, (did I say HOT traffic? <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" /> ) with A/C on and at least once a month I go out to the hill country and drive it hard for about 6-8 hours (in the HEAT!!!) <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Right now the gauge in 70 degree weather with no A/C will sit above the bottom white line, but sometimes creep up to about the 10:30 position before it will drop some. I don't know if that's because the thermostat just opened or because the fans came on. On a real hot day with the A/C running and I'm pushing it hard around 100mph up hills and down it will climb up to just a little below the top white line.
My goal is that the temp gauge rides a little above the bottom white line whether I'm just tooling around the neighborhood on a 70 degree day, or hauling *** in the hill country on a hot day. I realize it's going to vary some, but I'd like to stay within the 20 degree range that Flash quoted as a good range to shoot for. Right now I think I'm doing a 40 degree or so swing.
Suggestions on how to proceed? Which one(s) to try first? I'm open for suggestions and oh by the way, I'd like to keep the draining the cooling system and changing things out to a minimum! <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" />
P.S. I have checked and both fans run when the A/C is on...
